Engine Oil
Started by Nassau1969, May 24, 2010, 04:59:03 PM
Nassau1969
What engine oil are you using in your 440 (1969 1970), I'm using Mobil 1. Is it to thin for these motors.
RD
Quote from: Nassau1969 on May 24, 2010, 04:59:03 PM
nope, but it doesnt have the ZDDP that you need to rejuvenate the metal components in your engine without an additive.
WHITE AND RED 69
1969 Dodge Charger R/T
1999 Jeep Grand Cherokee
1972 Plymouth Duster
Charger72SE
valvoline VR 1   72 Charger with 440
resq302
Brian
Rolling_Thunder
bradpenn, 10w40 WITH zddp additive for peace of mind
elacruze
Royal Purple XPR 10w40 will be preferred, because it has good availability.
I haven't had to consider oils for 3 years now lol.
My past 'field testing' (7500RPM Sportster 883's) showed only a few oils which would prevent piston scuffing;
Royal Purple Racing
Bardahl Racing
Amsoil Racing
Klotz Racing
Mobil 1 20w50 (probably no longer)
Obviously, this is high-speed testing and the particular problem on these bikes is piston scuffing. There is no direct comparison to traffic-jam flat tappet cams with high spring pressures. YMMV.
1968 505" EFI 4-speed
68X426
Too thin depends on your specific motor, stock or mod, environmental conditions, your driving style, etc. I think it's reasonable to say that "too thin" is ultimately determined when your see what the wear looks like inside the engine. But too "thick" will be just as bad with every engine start, let alone in freezing weather (say a straight 50 or 60 weight)
All of us (most?) select the weight and type that we hope has the highest probability of optimal lubrication for 95% of our typical driving. And keep our fingers crossed. :Twocents:
VR1 10-30 (conventional) works great for my Hemi and my driving. I change it often. If I raced more I'd use 20-50.
Here's an excellent resource for you to explore: http://www.bobistheoilguy.com/cms/
And the site's viscosity chart: http://www.bobistheoilguy.com/cms/index.php?option=com_content&view=article&id=48&Itemid=55
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
Sublime/Sixpack
Switched to Joe Gibbs HR 10w-30 a while back. It'supposed to have the Zinc our flat tappet cams need.
Charger´69
Valvoline VR1 Racing 20W-50 and engine is ´69 440cid Magnum  :2thumbs: This is very good oil and oil pressure is always over midway in my Charger´s oilpressure meter  :2thumbs:
Plymouth Fury "Christine's Sister" 4x4 6-71 1959
Dodge Charger R/T 440cid 1969
Pontiac Trans Am T-top SuperBandit 400cid 1978
Jeep Cherokee Renegade 4x4 3.7 2006
moparmoynihan
I use diesel oil from Rotella t, It has the old properties that the old oils had back in the day. Johnny  :METAL:
b7 1969 Charger 4 speed 440 4:10
Dans 68
Brad Penn 20-50 in my 383 4-bbl.  :icon_smile_big:
Dan
62 Max
Quote from: moparmoynihan on June 01, 2010, 03:52:07 PM
Not for the last few years.
62 Max
You're answer is right here.
http://www.dodgecharger.com/forum/index.php/topic,46015.0.html
vancamp
im using valvoline VR1 69 440
charger2fast4u
so pretty much if you have older engines like us you most likely need to run an oil additive unless your oil brand you use has it already added in? i use castrol 10-30 in my 440. i'm not to good with what oils to use in what temperatures and motor applications could someone set me in the right direction on this? what weight oil is good to use in a  stock to mild 440 during summer anywhere from 70-100 degree weather? also if you use a zink additive like ZZDP how much do you put in with your oil? about to do a tune up and change the oil soon lucky a thread like this came up before i make a mistake.
chargergirl
Quote from: 62 Max on June 01, 2010, 08:05:47 PM
Seconding that.
Trust your Woobie!
billssuperbird
Highbanked Hauler
Quote from: billssuperbird on June 02, 2010, 06:08:44 PM
rotella  :2thumbs:
Same here but it sounds like a change is in order damn :icon_smile_dissapprove:
92 Cummins Turbo Diesel
04 PT Cruiser
Sublime/Sixpack
Quote from: chargergirl on June 02, 2010, 04:34:56 PM
Seconding that.
Based on what I've read I'd have to agree, Rotella isn't what it once was.
1970Moparmann
Quote from: c00nhunterjoe on May 31, 2010, 10:54:45 PM
Yep! :2thumbs:
clanton
HERE, HERE, AND HERE.
flyinlow
Mobil 1  15W-50 +  Comp Cams break in lube.  Mobil's web site states that 15W-50 has over 1300 ppm ZDDP which should be enough and recomends it for older style engines. I still am adding the break in lube, probably overkill . Change it once a year , about 5000 miles.  15.000 miles on the build, so far. so good.
Al
1968 Dodge Charger, 383, UU1
SFRT
Broke in my 440 engine rebuild with Royal Purple Break In...., and run Royal Purple since in the engine, Royal Purple in my 4 speed and Royal Purple in my differential. I have run the car HARD under all conditions for about 8000 miles total over 2 years...
no problems at all.
Always Drive Responsibly
Uploaded with ImageShack.us
