Tranny mounts
Started by irishluck, May 13, 2010, 09:22:39 AM
irishluck
does anyone know where i can find 727 small block tranny mounts. i think i have the rear mount, but i also need to know how many mounts the tranny has and where there located (i know this is a stupid question but i honestly dont know=/ )
lisiecki1
one mount located in the rear for the transmission  :2thumbs:
irishluck
ha yea i know that one, its still on there. do you know any others and also do you know if i need a crossmember mount to mount the transmission on the car?
lisiecki1
that one is the only one and it bolts to the trans with two bolts and to the crossmember with one long bolt and nut.
irishluck
that helps me alot thanks, by chance do you know where i can find a crossmember
also if i just mount the tranny up, will the cross member hold it there since the engine is not in there? (to me it just doesnt look very strong
cpthowdy1369
No, It would only hold the rear of the tranny up.  You would need to thread a rope through one of the top bolt holes and then tie the rope to something in the engne bay that will hold the front of the tranny up. Or put a jack under the tranny to hold it up.
DRIVE IT LIKE YOU STOLE IT!!!
or use a bar crossing from side to side over the frame rails to hold the tranny at two long bolts ( and nut ) through the housing holes. dunno if the threated holes will match the frame rail height, to not need a bolt with a nut
irishluck
any idea where to get a cross member? for a 73 charger
here... there... ebay...
irishluck
well ive googled it and cant find anything for it, i have found one off ebay for a 1974 dodge challenger,(will that work)
other than that i really cant find one lol
lisiecki1
i'm pretty sure you can make the one for the challenger work.
irishluck
i added the link on the other post so you can take a look at it
