fuel sender ground wire
Started by Tilar, April 21, 2010, 04:13:40 PM
Tilar
On my 73 the fuel gauge doesnt work. I checked the gauge and wire from the tank and it all works. I also noticed there is a ground wire that runs from the sending unit on the tank, Across the rubber hose and to the metal line that runs down the frame. This doesnt seem to be very tight at all. Where can I get this wire or should I somehow run another wire from the sending unit to ground on the frame?
Dave
FWIW, I added a second ground on mine.  The existing one was fine on my car but I was working under there one day and decided for the amount of time and money it would take, a little redundancy couldn't hurt.
Tilar
How did you connect it to the sending unit? I was thinking of maybe using a hose clamp and just clamping the wire to the tube coming out of the sending unit, and then going to the frame somewhere.
Dave
That's basically what I did. :lol:  I covered the mess with a little bit of silicone too.  It isn't pretty but no one will ever see it unless they are taking the car apart.
