msd-6al vs tach
Started by sound5262, April 12, 2010, 08:20:04 AM
sound5262
after installing the new ignition system, the tach doesn't work anymore. knew this going in, bought the msd adaptor from yearone, installed it and it still doesn't work. anybody got any suggestions? i'm sure i'm not the only one that has changed out to this system. i would appreciate your input, steve
Steve depending on the year of your car, if it's a factory tach it may have been made for a points dist. system. There was allot of trouble getting them to work "back in the day".
Cooter
Also, if you fired the car at all with the MSD hooked up to the stock tac, it will fry it and it will NOT work afterwards...Even with the adapter...I found this out the hard way with a 5.0 liter Mustang...
sound5262
i did contact msd @ problem and are checking in to it. 70 rr with factory tach. dont know @ starting it when it was hooked up, i do appreciate the responce from both of you. thanks agin, steve
1970Moparmann
We need to hear from "Master Ron".... I have the same problem.    :icon_smile_dissapprove:
hemigeno
There are two different styles of adaptors: one for points-type distributors, and one for magnetic-pickup-type distributors.  If you happened to get the wrong adaptor, that could be the problem.
I'm going through the same issue with my R/T right now.  Last year the MP orange ignition box was dumped in favor of an MSD 6AL, and the tach has been dead ever since.  Never took the time to order the adaptor until last week, and I ordered the magnetic-pickup style since that's what I'm using.  It may be a few weeks yet before the adaptor gets installed, but hopefully it will do the trick.
1970Moparmann
Quote from: hemigeno on April 13, 2010, 11:34:42 AM
I wasn't aware of the adapters you guys are talking about.  Anyone have a product code?
hemigeno
Quote from: 1970Moparmann on April 13, 2010, 11:44:12 AM
Try clicking on this link:
http://www.summitracing.com/search/?keyword=tach+adapter&dds=1
Below are the wiring diagrams/instructions for the two types of adapters.  The 8920 will work with either, but the 8910 will apparently not work with magnetic-triggered distributors.
Hope this helps
:cheers:
1970Moparmann
