My Suspension Rebuild
Started by bordin34, March 24, 2010, 07:32:17 PM
bordin34
I decided to start my suspension rebuild this weekend. I am basically doing a stock rebuild with poly strut rod and UCA bushings. I am also putting in 1.06" torsion bars and welding on reinforcement plates to the LCAs.
Here are some progress pics.
1967 Coronet Black 440 Auto
Mahwah,NJ
BigBlackDodge
Ooooooooooooo.......fun!
Keep at it! :2thumbs:
BBD
been busy !  :yesnod:   oh i see 3rd generations have a different swaybar attachment & lower control arm by the looks of it   :scratchchin:
  :popcrn:
Rolling_Thunder
Quote from: tan top on March 24, 2010, 08:06:34 PM
been busy !  :yesnod:   oh i see 3rd generations have a different saw bar attachment & lower control arm by the looks of it   :scratchchin:
   :popcrn:
I believe that was a 73+ thing...   also notice the rubber isolated K member, the different mounting (chevy style) on the upper control arm...
CDN72SE
Very nice work, I spy a ball joint socket, that's on my list of things to buy. I'll be following along as I'm almost at the same stage. Good luck.
1972 Charger SE
bordin34
Yup ball joint socket, breaker bar, 3 ft piece of pipe and its still hard to unscrew.
Mahwah,NJ
Quote from: bordin34 on March 25, 2010, 01:47:31 PM
yeah mine were very tight  even with a braker bar , was moving the vice & bench all round the workshop , (jk)  i ended up using a torch to heat it up first  :yesnod:
Quote from: Rolling_Thunder on March 24, 2010, 08:39:25 PM
  :popcrn:
 wonder why they went to all that trouble to change the set up
yes was looking at the upper control arm set up !! k fame insulators also !! looks very chebby :yesnod: bet the insulators make for a smooth ride :yesnod:
bordin34
Some new pictures from today. I got the passenger side upper ball joint and UCA off. Both UCAs are now soaking in some Simple Green, tomorrow I burn out the bushings and maybe remove the strut rods.
Mahwah,NJ
ChargerST
I got the rubber out of my ball joints without burning them - I just used a chisel and a hammer (I guess a screwdriver works too) and drove the chisel between the outer shell and the rubber, twisted the rubber a bit and it came right out.
EDIT: I meant LCA bushings not ball joints of course.
Dodgecharger74
are you going to change the K frame isolators  now would be the time  K frame will drop down lower and have more room to get them in & out with the UCA off
74 charger se
82 dodge PU fleetside short box 440
05 magnum 5.7 Hemi
04 rumble bee hemi
bordin34
My rubber is actually almost like new so I might have a hard time chiseling but I will try that. I am replacing the K-Frame bushings with poly ones.
Mahwah,NJ
bordin34
Here is a crappy cell phone picture of all the parts I will be using.
Mahwah,NJ
ChargerST
Quote from: bordin34 on March 25, 2010, 04:48:59 PM
My rubber was a little bit worn but not too bad. The rubber came out in one piece. It wasn't glued or so to the outer shell of the bushing.
Where did u get your suspension parts? Was it a kit or ordered seperately through a store?
bordin34
I ordered everything separately through rockauto and some other places. I wanted to be sure I was getting quality brand name stuff.
Mahwah,NJ
bordin34
Today I stripped the paint off and wire wheeled both UCAs. The bushings came out really easily and in one piece with a screwdriver and mallet. Tomorrow I will be putting the new poly bushings and ball joints in the UCA.
Mahwah,NJ
FLG
IMO,
You might have the same problem i did with those isolators, well the K-Frame in that area anyways. I think water tends to pool in that area of the K-Frame and rots the frame out around the bushing. You will see when you remove the two more rear k frame mounts. I had to weld patches on mine as a temp fix until the car goes back to the shop. I have a whole new kframe for mine.
bordin34
No real progress today, picked up a 440 instead. Thanks Frank.
Mahwah,NJ
bordin34
Didn't do much the past couple days. All I did was paint the UCAs, install bump stops, and installed the poly UCA bushings.
I am having trouble getting the lower ball joint separated from the spindle I think I am going to unscrew the two bolts that hold it to the spindle then break it loose.
Mahwah,NJ
bordin34
Here are some pictures of the UCAs. That gorilla snot they give you for the bushings gets everywhere.
Mahwah,NJ
bordin34
Today and yesterday I removed the lower control arms, torsion bars, and put in the alum. cross member bushings. The T-bars came out really easy since I wont be using them again I put some vice grips on there and they came out in a hit or two. The LCAs are at a shop having new bushings pressed in now.
Mahwah,NJ
Foreman72
great work :2thumbs: i'm definitely  going to reference this when i'd doing my 72
Eric "Foreman"
Previous: 1972 Dodge Charger
Current: 2002 Volvo S60
"The steps of a man are ordered by the LORD, and He delights in his way. Though he fall, he shall not be utterly cast down; For the LORD upholds him with His hand.
=Psalm 37:23-24=
"But store up for yourselves treasures in heaven..."
=Matthew 6:19-21=
:pat
bordin34
Here is what I did the past couple days, new bushings are in the LCA. I also welded on reinforcement plates, the welds look terrible but should hold fine.
Mahwah,NJ
bordin34
Today I installed new ball joints in the arm, a new pitman arm, a new idler arm, and new poly K-Frame bushings.
Mahwah,NJ
mopar73
Looking good. :2thumbs:  Where did you get the reinforment plates?  I was thinking of making my own, but if they aren't too expensive someone else can make them :D  Also, where did you get the new torsion bars?
bordin34
I got the plates from Mancini and the T-bars from ebay but they are firm feel 1.06" bars.
Mahwah,NJ
