727 or 904
Started by GN, March 19, 2010, 05:49:50 PM
GN
How can one tell the differance from a 727 and a 904?
OttawaCharger
They look almost identical.  You'll have to count the splines on the input shaft.  904 transmissions until 1967 have 18 splines in the input shaft. Non-lockup transmissions from 1968 have 27 splines.  Lockup 904 transmissions appeared in 1978, and have 26 splines.
Borrowed from: http://www.allpar.com/mopar/transmissions/identifying-torqueflites.html   :cheers:
1968 Charger -currently spread all over my garage!
GN
Nothing external or maybe a stamping? Are the 904 and 727 bolt patterns the same?
Charger RT
trans pan edge on passenger side is straight on a 904 and has a bulge at the front of that side by the dipstick tube hole on a 727.
Tim
RD
