68 Charger rebuild
Started by 68pplcharger, March 11, 2010, 09:07:33 AM
68pplcharger
Finally got to start rebuilding my 68 Charger on 12-26-09. I've attached some photo's of the car, before I started. This car already had half quarters put on and the body has been soda blasted and dp90 primed. This work was done before I got the car. The dp90 primer can't cover the poorly replaced trunk, from another rusted 68. Trunk was not put in correctly and needed replaced, the right way.
68pplcharger
more pics...
Skyview69
Looks like you're work is cut out for you...  :hack:
Good luck  :2thumbs:
:popcrn:
suntech
I assume you have called AMD?  :2thumbs:
68pplcharger
Quote from: Skyview69 on March 11, 2010, 12:01:56 PM
Good luck  :2thumbs:
:popcrn:
Definitely... The worste of it is over now. the trunk is in, just need to post pics.
Quote from: suntech on March 11, 2010, 12:14:36 PM
This charger will have more AMD panels than Mopar panels when I'm finished. ha ha
68pplcharger
more pics...
68pplcharger
more pics..
68pplcharger
68pplcharger
Not sure what happened on the last post?
68pplcharger
didn't download last time?
68pplcharger
68pplcharger
New pics of progress... finally
Test spray
68pplcharger
pics
68pplcharger
68pplcharger
68pplcharger
Car will be on a rolling chassis soon.
VegasCharger
I see the roll cage, those this mean its going to be a GL '68 style?
cdr
68pplcharger
Thanks cdr...
Vegas Charger
This '68 is going to be a corner hugger. car is going to have 17" versions of the original magnum 500's pretty modified suspension as well. shoud be a  lot of fun. The next step to fabricate the rear suspension. Coil over's and three link. I'm keeping the car as factory appearing as possible on the inside, minus the roll cage at least. The roll cage tubing is hidden from site when outside the car, with the exception of the main hoop. It's prettyhard to see at least. Removable side bars when on the street, Back seat still fits as well, and sun visors still work.
VegasCharger
Awesome another Charger saved by not being a GL!!!!!! Keep up the good work!!!!  :cheers:
myk
Quote from: 68pplcharger on August 07, 2012, 07:53:09 AM
Thanks cdr...
Vegas Charger
I love the direction that you're taking with your car, especially with the cage.  Is your cage installed?  I'd love to see it.  Is it a 'fabbed cage or did you buy one?
68pplcharger
Quote from: myk on August 08, 2012, 02:16:29 AM
Thanks cdr...
Vegas Charger
Thanks,the cage is installed and I fabbed it in my garage with a tubing bender i bought online for about $500. The picture above of the roll cage is only of a small section. There is no way to get what I wanted with a pre-made kit. This cage is legal for NHRA as well.
68pplcharger
I'm glad I cleaned the primer off of the car body. the previous owner had the car soda blasted and apparently they did a horrible job or they forgot a few spots. the trunk opening was all surface rust and they just primed over it.  :flame:
Spent three days cleaning off the rust and primer.
68pplcharger
re-primed the roof etc to protect the metal after cleaning all surface rust.
68pplcharger
