CIRCUIT BOARD
Started by tomfed, March 02, 2010, 02:46:39 PM
tomfed
Does anyone know if a circuit board can be repaired? (ie) the green strips that peel up?
Dans 68
I don't see why not. Post a pic or two that illustrates your problem and the collective will figure out a solution.  :yesnod:
Dan
tomfed
Thanks a million!
Dans 68
If the delamination is just in the circuit between the ground terminals of the gauges, simply add an electrical bridge between the grounding studs on the gauges. Use a proper sized insulator ring connector (photo attached) and crimp a wire between them. Then glue down (super glue comes to mind) or laminate down the raised edges of the broken foil circuit so it will not continue to lift off. The attached photo shows how to run the wire. The wire gauge probably should be between 12 to 16 gauge.
If more than just the one area is delaminating you can apply the principle above or get a replacement board (and I don't know how difficult that is to do). Good luck!  :2thumbs:
Dan
tomfed
thank's again i'll do that.
FWIW Charger Specialties reproduces the circuit board
http://chargerspecialties.com/
Dans 68
Quote from: Just 6T9 CHGR on March 02, 2010, 05:29:38 PM
Ahh, good to know!  :2thumbs:  And only $125.00!  :brickwall:  Well worth it if yours is in pieces.  :yesnod:
Dan
A bit pricey bit the board has the solid state limiter already built in....
Dans 68
Quote from: Just 6T9 CHGR on March 02, 2010, 05:33:52 PM
Then it is a good fix for those who also want to get a solid state limiter.  :2thumbs:
Dan
twodko
Tomfed
Try some super glue first before you shell out 125 samolians. Use only enough to repair the delam........not sure if super glue is di-electric. Keep us posted. Good luck.
Tom
Dans 68
Quote from: twodko on March 02, 2010, 05:59:55 PM
Tomfed
...not sure if super glue is di-electric....
If the repair helps to create continuity between the repaired sections then it is for the better. Dielectric problems (edit) "should" be non-existent as the ends of the repair will have the same voltage with the bridged electrical wire fix. Just keep to the original envelope of the conductive foil to avoid nasty and unforeseen electrical problems.   :2thumbs:
Dan
mike337
If that doesn't work, let me know.  I have a spare one I can send you for the cost of the shipping.
Mike
What about that "electrical glue" that you use to fix broken conductors in electric window defrosters?
twodko
I love it when you talk like that Dan!
Tom
tomfed
this is what its all about true mopar and car guys helping each other out.Thank's guy's keep the ideas rolling.
Dans 68
Quote from: Ghoste on March 02, 2010, 07:07:46 PM
You are right, but they can be pricey. I did a quick look up on Amazon and this goes for about $32 for qty (2) 7 gram tubes. http://www.amazon.com/gp/product/B0000WSZC8/ref=pd_lpo_k2_dp_sr_3?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000LX4JO4&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1EZH1TWM12CRREF6RHBT
Dan
PS - I'd also get Mike's extra board for the price of postage.  :yesnod:   :cheers:
Topher
I paid $65 for that stuff a few years ago. It works great, but use sparingly.
Topher
67 Charger 383-4spd "the Dawg"
www.headlightmotorman.com
