68 set up
Started by sixty8charger, January 24, 2010, 08:14:17 PM
sixty8charger
Hi everyone! Just got a rebuilt 69 440 from a member here. Here is my set up so far for my 68. Looking for advice, comments. 69 440 stock rods, piston, crank. New seals and rings.  assy only had roughly 50k orig miles no bore work was done.. Mopar purple cam/lifters  p/n p4286677 , rebuilt heads with 3-angle valve job. Doug 1 3/4 headers 2.5" H-pipes through flowmaster 50s.. Edle performer intake (also have the RPM intake) 750 edle carb.petronix elec distributor.MSD 6al, 727 tranns with shift kit (stock converter) and 8 3/4 with 3.91 sure grip. How am I looking? What HP/TQ numbers am I looking at?
Jayson
sixty8charger
Jayson
sixty8charger
re-addressing this post.. never heard anything back.
anybody have any guestimates?
Jayson
Brass
I wouldn't be qualified to guess but you could search in your area for a chassis dyno and get rwhp figures.  It would be fun too.
370-400  horse  may be , 480 foot lbs at the crank may be   :shruggy: :popcrn:  stock magnum was 350  , according to a stock type rebuild a mopar mag done years back  :o , although it was rated at 375 ,  :shruggy: :scratchchin: :popcrn:
sixty8charger
The Mopar purple cam/lifters  p/n p4286677...  how does that idle? smooth, or slight "lump"?
Jayson
Sixt8Chrgr
Quote from: sixty8charger on August 19, 2010, 04:03:02 PM
can you post the lift and duration?
sixty8charger
here is the CAM specs :popcrn:
                                DESIGN      REC.
                                LIFT @      INSTALLATION   VALVE LASH
ENGINE   CAM KIT #   CAM I.D.           DURATION   OVERLAP   VALVE         CENTERLINE   INTAKE EXHAUST
B Eng.   P4286677   D.C.-272-112         272            48             .455"      108                Zero
Jayson
Sixt8Chrgr
Your cam is mild. Should run fine like a stock car.
Rolling_Thunder
my desktop dyno spit out - 399hp @ 5000rpm  /  504 tq @ 3000rpm
sixty8charger
Alright.. That sounds good.  Just a nice cruiser with a little rumble. Cant wait to drop it in there
Thank you for the assistance
Jayson
sixty8charger
Alright..going to have the motor dissassembled and relubed double checked .. But now I want a more "fun" cam... What are some recommendtions.... The comp xe series 274?  Maybe the mopar 284/484  or  292/509?
Jayson
Jayson
Sixt8Chrgr
Quote from: sixty8charger on November 04, 2010, 11:57:02 AM
Jayson
Be careful. You may want to get more advice.
sixty8charger
anyone have any suggestions?
Jayson
Sixt8Chrgr
Ron on this site helped me with my build. I wanted a nice driver that had a nice lope and could run my factory air. Gave him the particulars of the car and he helped out. Firefigher is his "handle".
sixty8charger
Jayson
Rolling_Thunder
Everyone here knows I am a huge fan of Engle cams - They are not the only ones out there but I like them -
I build an engine similar to yours for a customer once and I ran the K58 / K60 lobes on a 110lsa...    Made for a nice street engine -
doctor4766
Jayson
Forget about power brakes with a 509
Gotta love a '69
