833 Trans case ID
Started by cbmkr1, January 21, 2010, 01:58:30 PM
cbmkr1
I have an 833 4 speed case i need ID C99129 case
Stamped 6B403819,
             PP833 5438
Welcome to the board cbmkr1 .
6B403819 is the partial VIN of a '76 car built at the Hamtramck plant.
PP833 identifies it as a New Process 4-speed, 5438 is the build date June 17, 1976.
It is an overdrive 833.
cbmkr1
What car would this most likely have been in?? Charger ,Daytona,Fury
resq302
Im guessing probably more something like a van or a truck since they did not make daytonas in 1976.
Brian
rt green
is it a cast iron or aluminum case? i.ve got a cast iron one thats spose to be an overdrive
third string oil changer
cbmkr1
Since the VIN says it's from the Hamtramck plant it's definitely from a passenger car, you need to find out which cars were built there in '76.....in earlier years Hamtramck was also called the "Dodge main" plant because Dodge A and B bodies were built there.
