Hi beams
Started by twodko, December 28, 2009, 11:01:51 PM
twodko
I've refinished the headlight cups for my 69 and have the hi beam cups marked separately. My bad, but I neglected to take note of whether the hi beams are the outboard bulbs or inboard? Thanks.
Tom
FLG
I think im reading this correct but you want to know where they sit on the car??
High beams are inboard, lows are outboard.
Excuse me if im reading it wrong.
resq302
If I remember correctly, there is indexs molded into the glass part of the bulb and it will allow you only one way to put them in.  This makes it so you can only put the high beams and low beams in a specific location.  High beams go on the inside towards the center of the grille and low beams go towards the fenders.
Brian
Charger-Bodie
2 prongs (high beam only) go towards the inside,and the 3 prongs (high and low beam) go to the outer most locations.
maxwellwedge
Most "buckets" I have messed with are stamped Hi and Lo or something to that effect.
I was hoping this topic was "different" type high beams.  :eyes:
twodko
This is the info I needed to reassemble the grille sub-frame light buckets correctly. I knew the bulbs registered only one way but couldn't remember which was inboard/outboard. Thanks guys. Neal, I was tempted to include a pix of some fine norcal "artesians" but didn't want to get a PM from Troy about it/them. hahaha.
resq302 I hope you're feeling better and the shift was relatively quiet.
Happy New Year to everyone..............it will get better.
Tom
resq302
Quote from: twodko on December 29, 2009, 12:57:36 PM
Tom
Tom,
Thanks for the warm wishes.  I am feeling better from the flu but now my right side jaw is swollen pretty well from an infected lymph node.  When will this year end?   :brickwall:
Brian
