Painting rear
Started by FLG, November 02, 2009, 09:02:21 PM
FLG
What are you guys using to paint your rear ends??  :icon_smile_big:
Not looking for "factory correct", just want it to look good.
68X426
Can't wait for the jokes.  :popcrn:
We Want to Help You.
1958 Dodge Pick Up, 383, loud
1966 Dodge Van, /6, slow
bill440rt
I did mine using Dupont ChromaOne urethane out of a spray gun.
Just want it to look good? Try Rustoleum brushed on with a foam brush.  :shruggy:
It's thick, black, and it will hold up under there. Easy upkeep, too.
OR, try Eastwood's Chassis Black epoxy-based paint. Great stuff! Covers well, and is a tough spray paint that resists chips, etc.
FLG
I have all the capabilities to spray stuff on, so id rather go that route since the finish will come out much better.
I dont want to have rear that looks like paint was just bombed on there, ill take the time to do things right but i dont mind if it isnt completely factory right. I think you know what i mean.
The chassis black looks like some nice stuff, do you think the satin or gloss will look better? Its a toss up for me.
Dadscharger
I used Duplicolor Gloss black brake caliper and drum paint on the rear axle in our car. I used this paint because it's a ceramic based paint and I figured it with hold up better to the heat created by the gears in the 3rd member.
Rob
66 Charger
400ci/727
3.23 Sure Grip
jaak
I had some black Nason Fulcryl acrylic enamel laying around the shop, so thats what I sprayed my rear with. (Also painted my torsion bars with it to. I painted the brake drums, etc. later when I rebuilt the brakes.
Jason
FLG
Looks good!
Think im just going to blast and epoxy prime the whole tihng then just use some of eastwoods satin stuff for now.
69charger440
I just did my dana 60 last week. Wire brushed the whole thing, then used degreaser and scrub it for about an hour. Then used poly primer and the Semi-gloss Engine high temp paint. Turned out great.  :2thumbs:
1969 Charger 540 Blown Hemi 1000HP, 69 Road Runner 500 Stroker 665 HP
BBKNARF
Semi-gloss Tremglad Rust paint.  :yesnod:
68 Charger, slowly in the works, 451 c.i. approx. 535 hp @ the flywheel, so far best time in the 1/4
11.21 @ 119 mph, full exhaust, stock suspension, 4:10s @ 3640 pounds.
motorcitydak
Check this stuff out. I have not had the opportunity to try it out myself yet but I will be using it around my car in various areas. Of course I have to finally decide on a color for the car before that too.
http://www.por15.com/HARDNOSE-PAINT/productinfo/HNGB/
96 Dakota, custom everything 4x4, 5.7 HEMI
'68 charger project
[OO!!!!!!!!!OO]
