Seam Sealer.
Started by Big Sugar, September 22, 2009, 02:19:38 PM
Big Sugar
Hey Guys:
  I'm presently in the midst of refreshing the inside of my 66 Charger , Gutted the interior and am in the process of scraping /sanding the floor and firewall down. I pland on priming the area with a Tremclad grey primer (Roll/brush on) and then Spraying "Lizard Skin" (  beadliner light )overtop.
Question is should I recaulk the seams with seamsealer ? Or will a doublecoat of Lizard skin suffice .
[img]<table border="0" cellpadding="0" style="border-collapse: collapse" width="182" id="table1" height="202" bordercolorlight="#ECEBF1" bordercolordark="#E9DFD1" b
Rolling_Thunder
I like seam sealer but a double coat would likely suffice   :2thumbs:
Silver R/T
seam sealer would be best as it's flexible, blocks a bit of road noise, vibration
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
Shakey
I also did the Lizzard Skin and prior to doing so I used seam sealer.
yeah would still seam seal the joints  :yesnod: , on the under side  also , as thats where moisture gets traped in the joints & stuff , i know its not factory but , better to do this  :Twocents: :yesnod:
my1st68charger
Would it be a good idea to spray lizzard skin under the whole car too?
Quote from: my1st68charger on September 24, 2009, 09:25:39 PM
yeah you can do , still better to seal the joints up first ,as you know they are sealed then ,  :yesnod:
