great idea
Started by 1charger69, September 08, 2009, 11:59:27 AM
1charger69
i see alot of 'grounding" questions and as we all know ..mopars are all about proper grounds.....how bout we make a list of every thing that should be grounded and where for all us dunderheads  :rofl: that are startin to put ours back together after years of being apart...a checklist if ya will we can go by...   :yesnod:
For 3rd gens:
-Radiator core support for headlight harness and battery ground reinforcement.
-Battery wire to driver head or A/C compressor
-Ground strap from passenger head to firewall
-Ground strap at wiper motor
-Dash frame above brake emergency handle to some dash functions ( map light, voltage limiter, seatbelt light insert ). Rest of cluster really gets ground by chassis, wire is a reinforcement
-driver side trunk reinforcement for driver side sidemarker ( also 73/74 full tail lights setup due the plastic housing )
-ground wire from steering column bolt to steering column holding stud
-ground strap at fuel sender outlet to fuel line at body
Some specific years grounds:
-71/72 passenger side trunk reinforcement for passenger side sidemarker
-ground on dash frame lip between ashtray and glove box to 74 interlock control
-eyelet terminal ( engine harness ) at one of the wiper motor studs to the reset button on 74s
-74 headlight harness carries extra ground wires to parking lights, but attached to same radiator core support wire net.
TylerCharger69
Ya know....that IS a good idea.....have a list of all of the grounded components...AND the exact location as to where they should be grounded at.....might just take a lot of guess work out of a lot of members' troubles :2thumbs:
