Head bolt torque
Started by 400/6/PAC, August 30, 2009, 03:44:52 PM
400/6/PAC
Anyone know the torque specs for stage 6 aluminum heads?
The Eddy RPM's are 70 ftlbs with oil on the threads....I imagine the stage VI's should be the same.  :scratchchin:
TylerCharger69
For what it's worth...make sure to use NEW bolts on aluminum heads...You aren't supposed to use used bolts on the aluminum :Twocents:
400/6/PAC
