Repair or replace
Started by mAdMoPaR, August 21, 2009, 12:33:05 AM
mAdMoPaR
Hello all, Long time reader first time post. Need a little advice on fixin the rear window channel on my 68 charger (see pics) Should I replace with new sheet metal? or does it look like i might be repairable? Gonna have the trunk floor replaced so I figured it might be easier to replace the deck panel at least with the trunk floor removed. Not sure how easy the sail panels are to replace though, not really a bodywork type.
69bronzeT5
It looks repairable but if you get the car sand/media blasted, it could open up a whole new can of worms and expose more non-visable rust.
mAdMoPaR
Thats kinda of what I was thinking. Although I dont think I'm gonna have it blasted ...at least not yet :icon_smile_big: I'm at the stage where I'm kinda just collecting sheet metal pieces I think I gonna need and have it all welded at the same time. So far the trunk and the window channel seem to be the problems, the rest of the car is pretty solid.
HollyWoodCharger
I think I'd be looking into the Sail Panel patch parts and a dutchman panel, and the lower back window frame, it may come with the dutchman panel depending on who makes it...
by the time you cut out the area or grind it out, it will without a doubt be larger than it looks now in these pics.
but this repair is not the end of the world, it'll take some patience to fix properly...
I have the same issues with my car but my trunk channels are shot also. I have bought L/R sail panel pieces and the piece from the window to the trunk but now AMD makes one that is better with the trunk channel built in and they make the channels to go with it. So I'll be buying them too! It's better to buy the whole section then try to weld little patches everywhere or use filler.
Silver R/T
just get a spot blaster and blast it yourself. Afterwards you can make patches and fix it yourself
2001 Ram 2500 CTD
1993 Mazda MX-3 GS SE
1995 Ford Cobra SVT#2722
TylerCharger69
I have that problem too.  I'm going to use a cut-off wheel to remove the bad  and then I'm going to use cut strips from 18 gauge steel wall studs for the repair....cut to size with the cutoff wheel as well...very inexpensive and really easy to get those bends...one could acquire these from the scrap pile at any commercial construction site.....Once it's fitted and tacked into place....you'd never know the difference!!! :Twocents:
mAdMoPaR
Well here the pics of the replacement panels that I have found so far. From what I can see, they look like they are all I need to fix this. Have thought of cutting and patching like SilverRT and TC69 mentioned after I glanced through a book called Project Charger which I sure some of you might be familiar with. They had a similar problem but used some kind of mesh screen and filler (lead?). I will try to clean it up a bit more this weekend and see how bad it really is. BTW what the heck is a Dutchman panel?
HollyWoodCharger
Quote from: mAdMoPaR on August 21, 2009, 11:27:54 PM
The bottom photo in your last post is sometimes refered to as the Dutchman panel..
That's exactly what I have also. The AMD filler panel forms the inside edge of the channel and seams like factory leading to the trunk side channels I need also.
Joshua
For the price of those panels, you could buy a small sheet metal brake, a shrinker and make your own panels....then you'd have the tools to make wheel lips and other pieces for various projects. :cheers:
1.  Don't be afraid to try to fabricate your own stuff from scratch.  Of course don't try to make a whole new fender or anything, but you'd be surprised how large of a patch piece you might make without ending up worse off than buying a repro.  It's not that your work will be that good, it's that the repros are usually that bad.
2.  Just because they sell you an entire panel, that doesn't mean you have to us it all.  Don't feel like it's always a waste of money if you spend $400 on a patch panel and then cut off & throw away 80% of it.  Even the best reproduction parts are generally worse quality than the original stuff.  And even if you're dealing with NOS grade replacement parts, the factory's spot welding & stuff is generally better left in place than redone.  If the old metal is straight & solid, then keep it.  At worst you can re-replace the whole panel at some point in the future.
mAdMoPaR
Didn't get a chance work it on this weekend after all. But I'll try again next weekend. What do you guys recommend for cleaning this up ? All I have is a driil with various wire brushes and a  4 1/2 electric da sander. Also have a puny craftsman compressor (3gal I think). Also figured this is a good a time as any to post a pic of my baby in her current state  :cryin:
Good start, nice deck and shade area. Watch out for the little wire wheel pieces...they hurt... :eek2:
lexxman
I have the same problem with my rear window area(just not as bad).I will be repairing it myself,and I think you you could do the same.It take a little more time,but you can save  some money.
The70RT
Like most said. Cut out what is bad and don't wast money on those parts....I don't think it warrants it.
mAdMoPaR
Thanks for all the input guys, I really appreciate it  :cheers: I've  been a  member of another mopar forum for years now and can never really get clear answer ( or only after constant bickering between members) Cool bunch of guys there too but man do they like to whine!  :icon_smile_big: May have to set this to the side for now as I started taking out the dash last night and will continue this weekend.
OneofNoneRT
I am far from done but I have learned a few things I will share...
1 Bag and Tag everything.. Usable or not you may need it for reference..
2. Pics.. alot!  pics are worth a million words.. can save you headache later..
3. RUST, Is Thou Enemy! There is 10 times more there than you realize...
4. Air compressor, BIG Holding tank, The larger the better, You will be blasting, even if spot blasting you will wipeout a small tank Quickly, and wasting valuable time and effort. Also a good DA or even a die grinder will outpace most residential compressors..
5. Sand blast Media gets everywhere! Avoid it if possible, But it is a neccessary evil..
6. sweep the floor before starting to work, Then after , any brackets, bolts, clips.clamps found that are not identified can go in with the days project. try to figure out where it goes now , not 3 years from now.
1968 R/T 440/4 Spd (Prototype Factory Sunroof)
2008 R/T 5.7l HEMI (Road & Track)
Good advice there.  Man, #6 is so damn true.
If you really are in the market for an air compressor then PLEASE, get an older design oil-filled one with a belt driven motor.  IMHO the modern "oil free" compressors are shit regardless of the brand or model.
And a compressor motor's CFM flow rating is much more important than the highest possible tank pressure it can achieve.
Belgium R/T -68
Had the same problem at the rear window,  used small selfmade pieces to weld in. the only sheetmetal I bought was the front floor.
And yes, like stated before: lots of pics and save EVERYTHING.
Per
lexxman
Hey,about that #6 so true,I got my car in boxes.Man do I wish I had taken it apart.Good luck and keep us updated. :2thumbs:
Charger440RDN
What did you decide to do to repair the window frame? Any updates?
mAdMoPaR
Haven't decided yet. Kinda set it aside for now and started working on removing the dash/windshield. Although I am leaning a bit toward repairing the damaged parts instead of replacing it with new panels.
elacruze
My rear was good on the bottom, but bad under the vinyl roof. Here's pics of the repair.
Too easy. Two pieces of sheetmetal, tin snips, bend by hand, weld in, grind, finish, paint.
YMMV.
1968 505" EFI 4-speed
mAdMoPaR
That's probably the route I will be taking. It was mentioned in some earlier post. What gauge sheet metal did you use? What type of welder did you use? (MIG,flux,etc.) I"ve been kinda researching a few mig/flux combo welders at Sears that are under 300 bucks. Any suggestions? I haven't welded anything since high school and even then I really just screwed around melting and burning stuff  :lol:
Should of paid more attention! ;D
elacruze
18 gauge, 90 amp lincoln MIG.
I have to add, that I'm not the body guy. I've done it, but not on anything I needed to turn out perfect; I don't have the patience for this much bodywork. If you want/need to do all your own work, I admire you for that. I had to admit that after owning the car for 30 years, I was never going to get to it.  :icon_smile_blackeye:
I'm digesting the strategy for the 'new' 440. I'm much more motivated by the part that makes noise.  :scratchchin:
green69rt
Quote from: Belgium R/T -68 on August 28, 2009, 02:59:13 PM
Per
I agree, think about some small patches first.  This is a good place to perfect your talents at making patches.  There will be more in your future.  Remember that the grinder is the welders best friend.
lexxman
Hey,that welder should to fine ,I got a 140amp lincoln.I'm a welder by trade and if I had the power requirement in my garage I'd had a full size miller.But for welding sheet metal the 140amp works good.I'll be glad when I'm done remodeling my downstairs so I can get back to work on my charger. :yesnod:
green69rt
Quote from: mAdMoPaR on September 05, 2009, 07:03:44 PM
On the subject of welding, are you experienced?  if not your local highschool or Junior college may have a short course to get you started.
I have a Hobart 140 and it has been great.  Got a good deal on it through Northern tools (I think).  Welder, cart, gas kit, self diming mask for about $550 with free shipping.  I learned to weld on big Lincolns and found it was harder to turn them down far enough to weld sheet metal.
The car is mostly 18 Ga with a litttle 20 ga and then some 10-14 ga for the frames and a small welder can handle all of those.  Don't try flux core unless yuou have to, smoke and splatter makes a mess, use shielding gas.
mAdMoPaR
No experience unfortunately. Have thought about taking some courses locally though. A buddy from work recommended a Hobart 125 I think. It does flux and mig and is kinda of newbie friendly.
green69rt
Quote from: mAdMoPaR on September 10, 2009, 10:28:54 PM
Does it have the gas option?  The smaller ones don't have the connections.  I advise not getting a welder without the gas option.   You'll get sick of flux welding really fast.
mAdMoPaR
Quote from: green69rt on September 10, 2009, 10:43:24 PM
Not sure. But I think I found the one he was talking about. http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_200127024_200127024
green69rt
Quote
Quote
That rig does not use gas unless you buy the adaptor kit ($90).  The description also says that it only uses 4 inch wire spools.  If you do much welding you'll run thru that spool pretty quick.  My 140 can hold a 10 inch spool.  I know it's more money but watch for a sale or look for a used one.  Spend some time and look around.
lexxman
A sheilding gas is a must for sheet metal and I would say try welding some scrap pieces together first to get a feel for it and to set the temp and wire speed. :2thumbs:
green69rt
Quote from: lexxman on September 11, 2009, 11:54:23 AM
:iagree:
roger01
I agree, use shielding gas or forget it.
And in terms of the ability to weld thick metal, all the welders tend to be advertised to be more capable than they are in the real world.
(For example I've used a couple of name-brand 120 volt MIGs that were advertised as being capable of doing 3/8" steel, but I wouldn't even trust them on 1/4" thick.)
Furthermore, it's easier to weld as a beginner if you err on the side of slightly smaller wire diameters and compensate with more voltage.  This is another reason not to try welding at the very edge of the machine's capabilities.
green69rt
Quote from: Mike DC (formerly miked) on September 11, 2009, 09:00:29 PM
Yeah, I use .025 wire and started at the lowest voltage setting to avoid burning thru the sheet metal.  As I got better I upped the voltage.  Practice and skill count!
lexxman
One thing to try as well,set the welder higher and do quick shot of the trigger in a row .You'll get good penetration and it won't heat the part as much.And if you're doing body panels don't weld to much in one spot at one time,because you may warp the panel.Keep a cold wet rag near by to cool the metal after welding. :2thumbs:
green69rt
This is turning into an online welding course.
Welding takes getting a lot of things right, wire speed, voltage, gas flow, and travel speed of the gun and these things change depending on metal gauge and composition, welder brand (they're not all calibrated the same) time of day and phase of the moon.  This is why practice is so important.
lexxman
That's what I like about this site.you ask a question and most time's you get info over load.If you want it or not. :lol:
mAdMoPaR
mAdMoPaR
Forgot all about this tread, I guess I'll continue using it for future updates and questions if its ok.
Finally done (somewhat) with the lower rear window corners. Just need a final skimming of filler.
Will post my results soon.
Moved on to the trunk floor. Removed old floor and center brace and cleaned it up a bit.
Have welded in the first half of a two piece kit and will hopefully have the second half in this weekend.
The floor came in bare metal and was wondering what's the best way to temporally protect it once its all welded in?
My car sits outside with no deck lid. Epoxy primer is planned for the future but not till I do some body work and find a spray gun that will spray the primer with crappy compressor.
It's epoxy primer that you need, you'll just waste time and money using anything else.  After stripping a car you need to get the epoxy on there.  Then you start the body work.  The first primer is sacrifical and is only there for temporary protection really.
Lose the crappy compressor and spend $50 - $100 on CL for a very nice used one.  Get the harbor freight gun, it's perfect for shooting primer and real cheap.
mAdMoPaR
I was afraid of that lol ok well I may have to push it up a bit.
I do happen to have a hb spray gun i got specifically for primer
http://www.harborfreight.com/air-tools/paint/industrial-paint-spray-gun-43760.html
Is this the one your referring to? I got it hoping that my compressor
Would be able to work with. It's a Campbell hausfeld 30 gallon 5.7 Cfm at 90 I think. Primer I'm thinking
of going with spi, seems to be the popular choice.
Quote from: mAdMoPaR on April 19, 2013, 04:43:10 PM
Not the gun I had in mind but it's fine, nothing wrong with an old bottom feeder!  I'm not familiar with spi but if it's epoxy it'll be fine I'm sure.  Compressor is a bit weak but it will work for primer.  I wouldn't spray clear with it as you don't have the option to stop painting half way, waiting for the compressor to catch up.  You can do that with primer however.
Mix the primer and activator by the manufactureres recommendation.  Don't try to thin it more or experiment with it when it's not working right.  Either adjust the gun or compressor but don't mess with the paint itself or you're going to be kicking yourself for a very long time.
Good luck and keep us posted!
Get the "HVLP" gravity feed gun from them. It uses less air and sprayed well for me.  :yesnod:
lexxman
Ya I picked one up a wile ago and painted my sons car and my motorcycle. Worked out nicely.
mAdMoPaR
Getting hot out!  :eek2:  so taking a break from trunk floor part two, got it all clamped up and ready to weld.
Base/clear is definitely out of the question. I never planned on doing that my self anyway. Way beyond me and don't exactly have ideal painting conditions in my little driveway lol. Once I have it all welded in I guess I can order the primer and look into the other guns. Thanks guys!  :2thumbs:
Patronus
Some SS colors look better than B/C  :Twocents:
'73 Cuda 340 5spd RMS
'69 Charger 383 "Luci"
'08 CRF 450r
'12.5 450SX FE
That's why I'm going with SS pure white, is it what I want (B5 Blue) no, is it good enough for now, sure.  :scratchchin:
fy469rtse
Quote from: mAdMoPaR on August 21, 2009, 12:33:05 AM
now is the time to do it properly, otherwise it will come back to haunt you later , cut it , get the new panels , I think charger specialtys have a good fit sail panels replace the deck or Dutchman panel you might also need lower window frame, you will know once you get Dutchman panel cut out, it will give you a chance to clean up plenum under that, even if you can't do body work, I'm sure someone has posted photos on here as a guide, at least if you remove all this and know you need , less work and cost for who ever does the work for you
mAdMoPaR
Window corners done!  :2thumbs:
mAdMoPaR
Finished truck lock support along with spare tire and jack braces/brackets.
mAdMoPaR
Will be skim coating welds with duraglas before primer. Should seam sealer come before or after primer? Was thinking of using Evercoat brushable seam sealer.
Fred
lexxman
