8 3/4 rearend
Started by 74roadrunner440, August 09, 2009, 03:18:16 PM
74roadrunner440
 :brickwall: hey guys can u tell me what rearend will work for a 74 roadrunner. I  was told that only 71-74 rearends will work on a 74 runner with 8 3/4. I'm looking for a rear end but every one has 68-70. Will these work or not? Also my car has the facory 9 1/4 rearend and want to put a 8 3/4 in it just if u wanted to know guys. thanks pat if uwant to cantract me u can at m16king@netscape.net or ph at 701 799 9491 thanks pat
craig
the 71-74 8 3/4 inch rear setups are different from the earlier ones....save a lot of headaches and effort, get one of those...i assume you are running a 318 0r 360....or 400 2V....if you go to a 8 3/4 inch setup, you will need driveshaft work, also..
ipstrategies
9 1/4 is a good rear end that replaced the 8 3/4 and I know you can get a sure grip if it does not already have. I have a 8 3/4 with 2.76 out of my 71 parts car but think you may need to make some adjustments to work on 74.
1971 Dodge Charger SE 383 Magnum
1999 Dodge Durango 5.9
1995 Chrysler LHS
