Heat problem
Started by trevor74, July 31, 2009, 12:37:28 PM
trevor74
I have a 74 charger and it feels like the heat is always on, no matter what there is always hot air coming through the vents. Is that normaly? Even when I dont have the heat on? And I checked the blower motor is not going so what exactly is the deal
lisiecki1
your coolant redirect valve may not be working.....
nascarxx29
Do you have cable or vacuum controls shutting air doors
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
trevor74
Im thinking its vaccum i found what looked to be a vaccum line that was just hanging down the other day. It had a little white ball type thing on the end that im assuming is to allow vaccum to only go one way and not suck something down.
FLG
Yep hook that up to manifold vac and it should close the door for fresh air thus eliminating your heat prob. I had the same issue.
