Column bearing problem
Started by MoparSam, July 28, 2009, 08:35:54 AM
MoparSam
Hey guys, got a little problem with a little bearing on a 67 Dart GT.  I was changing out steering boxes (putting in a manual unit) and as I was trying to get the upper bearing off of the shaft in the turn signal switch section of the column, the bearing came apart in a glory of little BB's and so far I haven't been able to find a new one at Year One or the Paddock (only the lower bearings are available).  Any ideas on where to find these bearings?  Oh and the car is auto in the floor if that makes any difference.  Thanks in advance!
'68 Charger R/T 440
'74 D-100 Adventurer 318
'75 Ramcharger 360 4x4 4 Speed
'78 Ramcharger 360 4x4 4 Speed
'67 Dart GT (Soon 440)
'05 Ram 1500 4.7
1/2 '71 Dart
ODZKing
Sam,
When I did my Charger, that upper bearing was still available through Chrysler.  I don't have my books here but I can get a part number for you when I get home if someone hasn't already answered.  But you may try calling a dealer IF they have the parts book and can look it up.
If they are the same as Charger several suppliers on eBay have them.
peepsrock
Chrysler part number 2265656, still available from Chrysler the last time I checked, try your dealer.
ODZKing
Quote from: peepsrock on July 28, 2009, 10:34:26 AM
:yesnod:  Yep, that's the one.  Same A body thru Imperial
MoparSam
Thanks guys, I really appreciate yall's leg work... or finger work in getting that part number, I thought I had really screwed up on that one.  It's good to know that it works on all of them too, Thanks!
'68 Charger R/T 440
'05 Ram 1500 4.7
1/2 '71 Dart
