i need a spring
Started by billssuperbird, July 27, 2009, 02:44:45 PM
billssuperbird
any one have a over center spring. for a 1970 roadrunner. i have one but it is for a abody :brickwall: if any one needs it let me know.
hotrod98
Someone was saying that you don't have to have one if you run a Centerforce clutch. Ever heard of that?
Normal is an illusion. What is normal for the spider is chaos for the fly.
Charles Addams
billssuperbird
nascarxx29
With centerforce you dont need stock spring
1969 R4 Daytona XX29L9B410772
1970 Coronet RT WS23UOA224126
billssuperbird
i want to leave the car stock. so were can i fine one. the one i have is not for a abody.but it is for a cuda.
jaak
any diaphragm type clutch, you don't need the spring, lever type...definately need it.
Jason
hotrod98
I have a diaphram style clutch in my cuda and I have to pull the pedal back up some times. It has the spring. Should I remove it?
Charles Addams
Hemi_tyme
If you have a Center force or any diaphram style clutch Always remove the over center spring.
Billsuperbird, I think I have a couple of the springs at the shop if you still need one. Ken
rav440
shouldnt an E body spring work for a B body ?  :shruggy:
1973 PLYMOUTH road runner GTX
billssuperbird
the spring for a ebody is longer.hemi tyme how can i get a spring from you. :scratchchin:
Brewer's Performance carries them as well:
http://www.brewersperformance.com/products.asp?id=43
Be careful! Lots of pressure on those things.
billssuperbird
ken i still need a spring from you. let me know thanks. :patriot: :drive:
