pitman arm seal question
Started by CB, July 26, 2009, 07:31:17 AM
CB
When removing the centre bar I noticed the worn pitman arm seal. When using the pickle fork to seperate the arm/bar the seal got ripped.
This company sells the seal to replace it.
http://www.jimsautoparts.com/steering_parts.htm
SP-1466P
Pitman Arm SEAL - 64-76 All A, B & E Body [New original Mopar part] (this is not the same as idler arm or tie rod end seal as others claim!)
$ 24.95 ea.
1) can I use the old pitman arm and just replace the boot?
2) if so, would it be hard to press it on since there is a metal ring in it, right?
CB
1968 Dodge Coronet 500
1) yes... but if you get new PA, will get also a new seal.
2) Metal ring is part of seal... some seals don't come with it. If comes with, is not a pressed in piece... Seal simply will sits in place with or without ring
CB
first pic : here's how the PA looks like  :eek2:
and then after cleaning it up a little
CB
Also noticed my steering box is leaking :RantExplode:
no oil left in the pump :icon_smile_blackeye:
I just made the steering box rebuilt job... WAS EXPENSIVEEEEEE... and I had just a leak on lower seal
Belgium R/T -68
Nice work you are performing there CB :2thumbs: If you order from jim's, be aware of the shippingcharges. :eek2:
Per
The70RT
Over here in the states most auto parts sell the boxes for about 125 and your old one. As long as your pitman arm is tight where the ball is your pitman arm is probably still good. Now those are what's pricey....about 150 for a new one. I got lucky here a while back and got one cheap from a member here  :icon_smile_big:
OldGuy
"I can tell by your sarcastic undertones, rude comments and total lack of common decency, that you and I could be best friends".
CB
Quote from: OldGuy on July 28, 2009, 09:41:50 AM
Chris,
Did you get my PM's?
Carl, thanks for the PM's! I didn't have the time to respond yet, saw it this morning and had to leave for work.
I'll PM you back later tonight!
:cheers:
CB
