440 source
Started by billfury, July 23, 2009, 12:01:09 PM
billfury
Looking to build my 440 using the 512 stroker kit.I,m being told to stay away from them and go with the Eagle kit. Anyone use 440 source? are you happy with them? Thanks
Rolling_Thunder
A ton of people around have used the 440 source sroker kits - the cranks need to be checked and on occasion they need minor finess - but this is no different than any other aftermarket crank
Belgium R/T -68
I have only positive experience with 440source :2thumbs:
Per
General_01
I used the 383>496 stroker kit from them. I had a good shop do the motor. I have not got it in the car yet. Looking at end of the month, early next month before I get the car going. The shop didn't have a problem with the kit. They did do a dyno run on it after the build. 555 HP and 610 ft-lb of torque.
1971 Dodge Charger Super Bee
496 stroker
4-speed
aifilaw
Quote from: Rolling_Thunder on July 23, 2009, 02:29:58 PM
'72 B5 Metallic Blue Hardtop
chargerbr549
I built a 512 in a 440 block and didn't have any problems with 440 source, runs great.
Kevin
Mick70RR
Quote from: chargerbr549 on July 23, 2009, 06:55:31 PM
Kevin
Same here, been running for nearly 2 years now.
1970 Road Runner, 505 cid, 4 speed, GV overdrive, 3.91 gears
11.98 @ 117 on street treads
