Motor Mount Removal
Started by pb24, July 08, 2009, 04:09:39 PM
pb24
I'm trying to replace the motor mounts on my 68 Charger with a 383. On the passenger side I removed the long bottom bolt and the two upper bolts that mount the metal bracket to the block, Their is a third bolt that bolts the metal bracket to the block but the nut is on the backside of the metal bracket and seems in possible to get to.
Even if i did get it off it would be pretty tuff to get back on. The drivers side looks like it is harder to get to. Any ideas would be helpful.
pb24
Well I got them off :cheers:. It wasn't easy, It just goes to show you that if you walk away for a little and come back to it differant ideas pop in your head
