dash vin plate
Started by Charger72SE, June 22, 2009, 09:35:22 PM
Charger72SE
so being the dumb a** I am, when I changed my dash from gold to black, I painted over the dash vin plate and have covered over the white Chrysler and Pentstar markings.  Does anyone have any ideas to get it back to normal?
thanks much for any ideas!
maxwellwedge
Well......You can remove it, get the right rivets and refinish the plate - I think ECS sells the decal/mask/screen whatever the offer. Or you can try some Goof-Off or lacquer thinner on a Q-tip and carefully try and remove the paint/dye.
And if those are the only two options, then you may as well try the careful cleanup one first because if you are going to have to go to re-decaling (that's a word, I just invented it) the thing, then you have nothing to lose. :Twocents:
Charger72SE
thanks guys for the comments
what company is ECS?  I tried to Google the name and didn't get any car parts companies in the results
I'd like to find the decal/mask.
thanks again!
maxwellwedge
Try ECS Automotive Concepts
Does that mean that trying to clean it off didn't work?
Charger72SE
when I starting cleaning off the paint, all that was left was the aluminum/steel - so I'll need to strip the vin plate completely, spray it black, and then hopefully have a decal/mask to get the white Chrysler & Pentastar logo back on
Charger72SE
ECS Automotive Concepts offers the Chrysler VIN transfer.  The cost is $24 for the transfer and an additional $25 if you need the original Rosetta rivets.
You can call them at 636 207-7767 if you would like to place an order.
