Paint code questions
Started by ronwest, June 22, 2009, 01:36:23 PM
ronwest
Can anyone help me decode this build sheet info?
Trim code CRX
UDF color X9
Paint color W1
Vtop 1X
Engine 86
axle 595
Pshaft 162
Thanks! :drool5:
X9 for the UDF is a black upper door frame, W1 is white, V1X is a black full roof vinyl top, 86 is a 440HP.
What year and model are we dealing with?
ronwest
  :yesnod:
CRX is  the trim code for a SE charger CRX = vinyl & leather  black
is there a A47 on there also ????
  not sure if you could order the CR * trim  with out the SE option  :scratchchin:  check out  Chris not just 6T9  & his 69 charger registry !!
http://www.1969chargerregistry.com
any pictures of the car would love to see them sometime
hemi-hampton
The 595# means 8 3/4 sure grip with 3:23 gears with 11" drums &  1 7/8" pinion. The #162 means your Driveshaft is 3 1/4" diameter, 52.07" long for automatic with 8 3/4. Hope this helps?  :scratchchin: :shruggy: :Twocents: LEON.
ronwest
excellent!! Thank you so much!
:icon_smile_cool:
