383 Alternator Bracket:
Started by Captain D, May 24, 2009, 12:58:54 AM
Captain D
Hello all,
I am just curious to see where you may have found the triangular shaped alternator bracket for a 383, 4 brrl, BB 69' Charger in chrome. Perhaps, I could just have my old one powder-coated in a gray/aluminum finish. But everywhere I find them new, they say that they fit a 383-440 block, but they are not interchangeable. I learned that the 440 is approximately an inch wider than the 383 and cannot be interchanged between these two motors. I realize that I could buy stock brackets, from say the Paddock for example, but I was just curious to see if anyone has purchased a chrome bracket specifically for the 383...Thank you for your time and for any info.
All the best,
Aaron
mikepmcs
Aaron,
I know this isn't chrome like you are looking for but the reason I'm posting it is because I believe they are the same for the 383 or 440(ie: interchangeable)
I bought this exact setup BTW(i have a 383)
Alternator Bracket Kit 1967-74 Big Block
http://www.megapartsusa.com/proddetail.asp?prod=101-ABK987
Is this an A/C or non A/C car.....maybe that is what they meant by not interchangeable as they take different brackets depending on that option.
Here are a couple but just so you know, they aren't exactly like the original as far as number of holes etc...(compare the pictures with the link from megaparts above)
$13
http://www.motorchrome.com/servlet/the-491/chrome,big,block,mopar,dodge,alternator.bracket/Detail
$20 shipped
http://cgi.ebay.com/ebaymotors/Chrome-Chrysler-Mopar-Dodge-Alternator-Bracket-383-440_W0QQcmdZViewItemQQ_trkparmsZ72Q3a1205Q7c66Q3a2Q7c65Q3a12Q7c39Q3a1Q7c240Q3a1318Q7c301Q3a0Q7c293Q3a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem5d24e9a923QQitemZ400051251491QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
maxwellwedge
Stock non-ac 383/440 cars used the same bracket. There are two holes on one of the triangle points - the one that goes to the head. One hole is 383, the one on the very outside is 440.
mikepmcs
That's really strange as all these listings say it will fit either 383 or 440... but.... the brackets only have one hole where there are 2 on a stock bracket. :shruggy:
http://shop.ebay.com/items/_W0QQ_nkwZ383Q20chromeQ20alternatorQ20bracketQQ_armrsZ1QQ_fromZR40QQ_mdoZ
maxwellwedge
Typical misinformed(?) ebay sellers. With one hole they are going to either fit a low block or a raised block - not both.  :icon_smile_dissapprove:
The stock bracket is what he should have chromed.
mikepmcs
Thanks Max, that's what I was fishing for.  Appreciate the clarification.   :cheers:
maxwellwedge
No problem - I have been burned on ebay before and hate it to happen to others.  :2thumbs:
Here is a stock non-AC 361/383/413/426/440 bracket. I know, I know - the heater hose bracket is not on yet.  ;D
Because of the 413/426/440 being a "Raised Block" - taller deck, the heads sit higher too, hence the two holes.
Captain D
Thank you fellas for the responses, all of this stuff is awesome to learn about. Below is a link to another seller on the net. He has them in either black or chrome finish (w/ hardware included). His has the two holes (for either the 383 or 440), and w/out AC, so it should work it seems. Anyone purchase from this place:
http://www.bouchillonperformance.com/BPE5250.asp
Thank you again!
Aaron
mikepmcs
I say get it.  Looks like it has all the correct hardware and spacers as well. :2thumbs:
Bouchillon is reputable.
Captain D
Hi there Mike,
Yeah, I'm going to call tomorrow  :cheers:. Thank you again for the info; everything was valuable!
High regards,
Aaron
1968 Charger B5
Anyone have pictures of the ps pump bracket and pulley for the same setup   440 non-ac
1968 Dodge Charger R/T
1970 Dodge Charger
1974 Plymouth Roadrunner
1998 Jeep Cherokee SRT
resq302
If you need a bracket, I have a spare one for my car.  I ended up getting two when I only needed one.   :slap:  Let me know if you would want it.
Brian
wondering about 383/440 bracket FOR AC CARS... never have seen being different and the should be like non AC cars. At least not stated
gtx6970
Quote from: Nacho-RT74 on September 15, 2010, 12:01:17 PM
A/C cars the alternator mounts with the compressor bracket - and they are unique to engine size
gtx6970
Quote from: Nacho-RT74 on September 15, 2010, 07:36:25 PM
a little bit disagreed
maybe I'm thinking small blocks  :scratchchin: - either way I'm pretty confident the B/RB engines with factory air - the alt brackets are engine size specific
1969 383-440 with air
gtx6970
1968 small block with air
Cooter
I got one dem chromium Brackets for the NON-A/C 383-440 with the two holes and I thought it was Factory chrome, but it must be on old Direct Connection piece....Hmmmm...
Quote from: gtx6970 on September 15, 2010, 08:47:13 PM
yeah it looks it is... but on BB they are not part of the compressor bracket as at least I understood from you  :scratchchin:
1968 Charger B5
Still would like to see picture of 440 non-ac ps bracket and pulley setup/crank    please
1970 Dodge Charger
Sixt8Chrgr
I am putting a 440 in my 68 383 car with A/C. I have been told the alternator brackets are the same. Can someone confirm? I was not sure it was confirmed earlier in the thread.
Thanks,
