front tire problem
Started by mopar0166, May 20, 2009, 01:35:51 PM
mopar0166
I'm running into a rubbing problem with the tires that i got with the charger, they are 275 60 r 15's all the way around.  it mostly rubs on the lower fender when i turn left?   what size will work with a 15x8 rim to allow more room to turn the wheels?  the rims are from a later 70's dodge aspen i think  :shruggy:
any guidance would be awesome thanks guys  :cheers:
Hemidog
Wow, those are some BIG front tires!
I'm running 225/60-15 tires in the front with 15x8 wheels, but most people go with 235/60-15 tires.
No rubbing  :yesnod:
FLG
Got to recheck but believe mine are 245-60-15 with no issues. Those tires are a bit to big IMO. If i remember it might even be unsafe to run such a large tire size in the front.
mopar0166
thanks guys, i have found a set of 235 70 r15's i might try to see if it makes a difference , i just didnt want to have to get into finding other rims.  thanks again i let you know how i make out
