hemi oil pan ?
Started by 69chargerR/T, May 10, 2009, 06:39:45 PM
69chargerR/T
I installed a hemi oil pan last year on my 440 and I don't remember how much oil it took, I thought it was 6 qts. Anyway I just changed the oil and filter and I put in 5 qts. started the car shut it off and checked the oil, and its right on the full mark. I thought the hemi pans held 6 qts with the filter.  How many qts. of oil should a 440 with a hemi pan hold with a filter change. Could my dip stick be wrong :shruggy: Do I need to change the dip stick and tube when using the hemi oil pan on a 440 :shruggy:
maxwellwedge
Did you fill the filter with near a quart and then put in 5 quarts or was five quarts total?
69chargerR/T
Quote from: maxwellwedge on May 10, 2009, 06:42:37 PM
It was 5 qts. total.
The Hemi pan holds 6 qts plus the filter. What dipstick are you using Alan ? MP replacement dipstick ? :scratchchin:
69chargerR/T
Quote from: firefighter3931 on May 10, 2009, 07:35:17 PM
Its the stock dip stick, at least it sure looks like the stock dip stick it was in the motor when I got it.  When I first put the pan on I thought for sure it took 6 qts. So I got 7 qts. of oil so I would have an extra qt. I put in 5 qts. ran it and then checked it and it reads full. Checked the oil the next day before I started it and it reads right on the full mark :shruggy:Are you saying the hemi pan holds 6 qts. plus more for the filter :shruggy:  What's the total qts. of oil with the filter changed, 6 1/2 or 7 qts.  :shruggy:
Its 7 qts total with the Hemi pan....I run the same on my 440
Which reminds me I have to pick up some more Rotella T for this years oil change ;)
Quote from: NOT Just 6T9 CHGR on May 10, 2009, 08:33:16 PM
Yep, that would be correct !  :yesnod:
Don't forget to add a bottle of EOS or ZZDP+ to the mix.  ;)
69chargerR/T
Well, I don't understand :shruggy: I got the hemi pan and pick-up from mancini I got 5 qts. of oil in it and it reads full on my oil dip stick :shruggy: The dip stick looks OEM, but how do I know for sure that it is ?  I don't want to run my motor 2 qts. low. Should I get another dip stick and tube, where can I get a replacement dip stick and tube. Its a 440 with a hemi pan do I use a stock dip stick and tube for a 440, or do I need a hemi dip stick and tube. I'm not sure what to do here, you guys say it should hold 7 qts. Going by my dip stick its full with 5 qts.
jerry
duh,duh,duh. hemi pan = 7 quarts.duh mark your dip stick with a notch from file.
69chargerR/T
Quote from: jerry on May 11, 2009, 07:45:53 AM
duh,You must like doing things the "micky mouse" way. I would rather have a dip stick that reads full on the full mark. duh.
bull
I've never seen anyone belittling you in the answers to your questions. Do you think it's possible for you to extend the same courtesy?
resq302
I have a repro dip stick and tube that I think I got from the paddock years ago.  I am pretty sure that the 383 with a stock 402 oil pan took 4 qts plus the filter?
Brian
jerry
69chargerR/T
How can I tell that the oil pan I got from mancini is a 6 qt. hemi oil pan ??  Also how can i tell if I have the correct oil dipstick ?? If the hemi oil pan holds 6qts. then the oil pan I got is not a hemi pan or the dipstick is not correct.
Snap a pic of your oilpan and post it....the hemi pan is easily identified.  :yesnod:
You might just have to remark your dipstick...no big deal.  ;)
jerry
as said before  the hemi oil pan Mancini sells holds 7 quarts with filter.if you have a 402 pan you can see a big difference. if not the hemi pan is a about an inch or less below k member.i have been running a Mancini pan for 20 years and just changed oil in my car. with 7 quarts of Valvoline premium blue 15-40 diesel oil a filter and 8 oz of EOS my factory 440 6-bbl dipstick is on add line. so when i look at it and its on add line i know its full. i can measure pan for you from block flange to bottom of pan in a little while if you want. car is already up on lift plus my new motor is on engine stand with Mancini hemi pan that i bought and installed 2 years ago.note the hemi pan Mancini sells is repo of 71 pan which is not the same as what you would find on a 69 but fits and works just fine.
69chargerR/T
Ron, I know I could just mark the dipstick. I guess my question is did all you guys that installed the hemi pan have to remark your dipstick, or did it read on the full mark with 7 qts of oil in the hemi pan ?  Jerry, thanks for the info, my oil pan is about 3/4 of an inch or so below the K-frame. So you say your dipstick reads on the add mark with 7qts. of oil in it. Can I just get another dipstick that will read correctly ? does every ones dipstick not read correctly with the hemi pan ?? I know this sounds like I'm being real picky here, but if I can get a dipstick that will read correctly thats what I will do. Thanks for all the help.
Yes, I remarked my dipstick as well.  The Hemi dipstick tube/stick combo wont work on a 440 because I believe the hole is different in the block?  Dont quote me on that though.
Mine is from Mancini as well ('71 Hemi style pan)
jerry
the hemi pan measures 5" top to bottom. you might try stick out of truck 440 , 400 or 360.just checked oil ,car has been sitting 3 days and it reads on add mark 1 quart low which is full and how i have been running it for 20 years.
Quote from: 69chargerR/T on May 12, 2009, 07:33:19 AM
Alan, i've had the dipstick read differently in the last two Hemi Pan installations i've done. One dipstick was a stock 440 part and the other was an aftermarket dipstick from MP. I just changed the oil....fired it up to circulate and prime the system and shut it off for 5 minutes to allow for the oil drainback to the sump. Then a made a "new" full line on the stick.  :2thumbs:
bull
You'd think someone would have made a dipstick for these applications by now since it's such a popular swap.
69chargerR/T
Quote from: NOT Just 6T9 CHGR on May 12, 2009, 07:43:32 AM
I was going to take a pic of my oil pan but, my oil pan looks just like the one in the pic that not just 6T9 CHGR posted. So I guess I'm going to have to put 2 more qts of oil in my motor and then mark a new full mark on my dipstick :rotz: Like Bull said I can't believe no one makes a dipstick for these oil pans :rotz: Also, my oil pan is 5 inches deep, just like jerry had said. So my oil pan must be the hemi pan. Thanks guys for all your help :2thumbs: :2thumbs:  Alan
maxwellwedge
The 70-71 Hemi pan is the same pan as a 70-71 440 HP. I think someone was making the tube and dipstick for these (440). I wish someone made a good 69 tube  :'(
Quote from: maxwellwedge on May 12, 2009, 06:50:52 PM
AFAIK you can still get these from the dealer???
charger2fast4u
sorry if im threadjacking but i'm thinking of going with a hemi oil pan since i have to replace my oil pan gasket on my 440. is it worth the investment to go with a hemi pan over a stock 440 pan? is the hemi pan the best pan to get or is an aftermarket 440 pan bettter?  what parts are all needed to do the conversion? and as long as you put 7 quarts of oil in your good on oil? just mark the new reading on the dip stick and your fine? thanks
maxwellwedge
Quote from: NOT Just 6T9 CHGR on May 13, 2009, 02:26:43 AM
I can give it a try but the 69 tube exits on the outside of the exhaust manifold - the '70-up snakes between the head and the exhaust manifold. I'll run the part number (on the 69) and see what comes up and let everyone know.
Rick Ebooger sells them NOS & they fit all years....they are the same I believe...you just have to bend the tube to fit....when I put mine originally I had it between the manifold & block ala '70 style.....took it out & rerouted it outside the manifold for the correct '69 style....
http://cgi.ebay.com/ebaymotors/Tube-set_W0QQcmdZViewItemQQimsfpZTL0905111310005r9979QQimsxZ20090511QQitemZ220412431662QQsalenotsupported
This is the part # from the '69 parts book
3462416 for the tube  (a few dealers have it) using Partsvoice.com
2899246 is the stick (a few dealers have it) using Partsvoice.com
maxwellwedge
Quote from: NOT Just 6T9 CHGR on May 13, 2009, 04:09:23 PM
Oh great - Now everyone knows!  :smilielol:
