318 cam?
Started by paulgrr63, April 28, 2009, 01:29:01 PM
paulgrr63
I am sure this topic has been beaten hundreds of times but I gotta ask. What is a good cam for a 318? It is all stock and was thinking about getting this package from summit http://store.summitracing.com/partdetail.asp?part=CMB-03-0162&view=1&N=700+
After doing some reading I'm starting to think the Lunati cam might not be such a great idea? Can someone point me in the right direction? Thanks
Rolling_Thunder
you look to have a 73 Dodge Charger...   If your engine is indeed all stock you'll be fighting a low 8.6:1 compression ratio...     the way to make power with this is to go very conservative on the cam...   less overlap allows for less cylinder bleed off...
Realize that this engine needs compression to really make power.
paulgrr63
I was thinking about adding some 360 heads as well.
WingCharger
Your Charger is SHARP!! :drool5: :drool5: :drool5: :drool5:
paulgrr63
mopar_nut_440_6
That engine would be perfect for turbocharging!
1968 Charger R/T 440
2004 Dodge Ram 2500 680 HP Cummins with attitude
paulgrr63
Quote from: mopar_nut_440_6 on April 28, 2009, 03:19:26 PM
Dont get any ideas :icon_smile_big:
mopar_nut_440_6
Haha... I have seen /6's bone stock internals running high 12's on street tires and getting 20 MPG!
bordin34
While the 360 heads have bigger valves and ports, they also have a larger combustion chamber which will further reduce your compression ratio.
1967 Coronet Black 440 Auto
Mahwah,NJ
paulgrr63
Quote from: bordin34 on April 28, 2009, 06:46:26 PM
In other words....stay away from them?
Rolling_Thunder
Quote from: paulgrr63 on April 28, 2009, 07:16:08 PM
unless you plan on rebuilding the bottom end with different pistons...
If you're keeping the stock short block than yes - stay sway from the 360 heads...
paulgrr63
Quote from: Rolling_Thunder on April 28, 2009, 07:42:10 PM
Ok thanks. So here is what I have so far that I am going to order. Edelbrock Performer Dual plane intake, Holly avenger carb(670cfm), TTI headers, and this cam: http://store.summitracing.com/partdetail.asp?part=LUN-60401
How does this look?
I like that package but would change the cam profile for something more conservative. What are the rear end gears ? Stock torque converter ?
paulgrr63
I can get my hands on 1994 Magnum heads. Should I bite?
paulgrr63
Quote from: firefighter3931 on April 28, 2009, 09:26:01 PM
I have 2.71 gears in the rear (Thanks 69CoronetRT :cheers:). And yes, it is a stock torque converter(Plan on getting a 2250 stall soon)
Quote from: paulgrr63 on May 01, 2009, 09:32:52 PM
Personally, i would be looking to swap in some deeper gears long before upgrading the tq converter.  :yesnod:
Those 2.71's with a stock 318 will make the car feel very slow....a gearset will really wake it up. How tall are your back tires ? Taller tires only compound the problem by reducing the final drive ratio so that needs to be taken into account when picking gears.  :Twocents:
paulgrr63
Quote from: firefighter3931 on May 01, 2009, 10:12:45 PM
I will measure them tomorrow :cheers:
paulgrr63
The back tires are 24".
Paul, any plans to go with a taller tire ? A set of 3.23-3.55 gears would be my choice.  :yesnod:
paulgrr63
Quote from: firefighter3931 on May 02, 2009, 09:11:38 PM
I am leaving the tires that it has now. I think they look good :yesnod:
This might be a stupid question......but where do I get the gear set? Exactly what do I have to order? Again, forgive me for the stupid questions. I'm not the most car savvy person. Im still learning! :cheers:
Dr Diff can fix you up with all the needed parts  :2thumbs:
doctordiff@gmail.com
paulgrr63
Quote from: firefighter3931 on May 03, 2009, 07:52:34 AM
Sent him a message. Thanks for all your help :cheers:
paulgrr63
Still no response :shruggy:
Purple440
Who is this Dr Diff anyway?  I'm looking for a set of 3:91's....
