Need Spare Tire for 68
Started by 68-Grrr, April 21, 2009, 08:02:21 AM
68-Grrr
Have a 68 Charger and I'm looking for a spare tire.  Any suggestions?  What exactly am I looking for?  I have been searching the web for weeks without any leads.   :brickwall:  Any help would be appreciated.
Just get a 15 inch rim from the junkyard they fit fine.
Are you looking for a "stock" spare or a spare that will work?
PS---post up some pics of your ride!!
1BAD68
Ford rims also fit our Chargers
I bought these for $25.00 from a dodge van, had them sandblasted, painted with semi-gloss black and a set of used tires for $100.00.
I have about $150.00 in all of them.
You have to be careful with the Ford rims though, even though the bolt hole circle is the same (or close enough to work), there are some of the Ford wheels where the center hole is to small to go over the axle ends on the 8.75.  Make sure you before you buy.
Wonder what space saver off 70-80's would work? My trunk is always full of tools I could use the room.
