instrument panel
Started by mikes4692003, April 06, 2009, 06:12:09 AM
mikes4692003
how do you remove the instrument panel gauge cluster
Back N Black
mikes4692003
terrible one
It is held in by phillips screws that you'll be able to see the heads of looking at the bezel. The only thing you will have to do if you want to make it a lot easier is drop the steering column so that it will come right out. Once you have it out and in your hands just unplug the harness from it and there you go.
69bronzeT5
You can get it out with the column in. It takes some fiddling but it'll come out. Just unplug everything in the back (make sure to tag the wires) and unscrew the cluster.
