Started by dd44068, April 07, 2009, 04:05:20 PM
dd44068
I need some help. I am getting ready to send my tranny out to be rebuilt. Where can I find the tranny numbers? Also is there anything else I should be aware of? Thanks in advance Dom
mikepmcs
You should contact this guy for a tranny rebuild first, that's my advice.
His name is Jamey H. (RD) profile below.
http://www.dodgecharger.com/forum/index.php?action=profile;u=27
RD
thanks mike!  your numbers are located in two different places, on the pan rail (right above the trans pan) on the drivers side of the transmission (right below the shifter lever, and on the passenger side bellhousing on a "pad".  Now dependent on the year of your transmission, you may have a full VIN stamp on that pad or just the serial number of the vehicle.
the first set will tell you the year, body style of vehicle, and what engine the transmission was built to sit behind.
the passenger side set will provide you with a direct numbers matching component to the vehicle it was built for.
