Is this a good radiator?
Started by miller, April 07, 2009, 07:39:07 PM
miller
http://www.championcooling.com/champion_page_006.htm
3 core all aluminum radiator with transmission cooler for 219.50...
is it a good radiator?
2005 Harley Davidson 1200 Sportster Custom - Maggie
2012 370Z NISMO - Courtney
1979 Corvette L-82 - Lilly
1969 Dodge Charger R/T Clone - Vanessa
Quote from: miller on April 07, 2009, 07:39:07 PM
That looks exactly like the one i bought on Ebay for my car....fits great and bolts into the stock location if you originally had a 26in core opening. I haven't run the car yet but i'm sure it will work just as good as any other dual pass high flow aluminum rad.  :2thumbs:
One of the members here has the same radiator in his car and had good reports on it.
john108
Does this radiator clear the stock clutch fan set-up on the 440?
The same envelope and fit?
Hemidog
How do you know it fits your car? I don't see a word about which car it fits on the whole site...  :scratchchin:
Jesco
That looks just like the one I install in my 69 charger. Fits almost perfect. The only thing I did was to file/drill a little in one of the brackets who attach the radiator to the car. I have the heavy duty clutch fan and it's no problem. The fan cover bolts not directly on. Have to drill new holes in the plastic stock cover. Think some 1970 charger fan covers is bolt on.
Then I paint it with etching paint then the eastwood radiator paint - gives a stealth look  :2thumbs:
It's cooling my 520 with no problems...
1964 Dodge 330 Super Stock Clon
Jesco
Quote from: john108 on April 08, 2009, 01:05:48 AM
John, for some reason i could not get mine to work with a clutch fan setup. I ended up using an electric pusher fan.  :yesnod:
Another member used the same rad in his car with a clutch fan and shroud :
http://www.dodgecharger.com/forum/index.php/topic,37605.0.html
This is the rad : http://www.radiatorsus.com/servlet/the-1756/DODGE-CHARGER-NEW-ALL/Detail
chargerman67
I just purchased that radiator and got the twin fans with it. It looks great but haven't installed it yet. I will let you know my thoughts on it in a  few weeks. I figured for the price it would be worth taking the chance.  :icon_smile_wink:
67 Dodge Charger 440
87 Toyota Supra 2.5L twin turbo (JDM)
95 Impala SS
97 BMW 528i
mopar0166
mopar0166
khodne
I had to "massage" the fan shroud to get it to fit correctly.  I also had to install the backing nut without the holder as the flange was wider than the clip.  Running in the shop and outside yesterday it seems to cool very well.  I have a Mancini Racing high flow water pump and housing.  Inside a closed building with the exhaust out the door it would reach 185 and didn't fluctuate.
khodne
From the front.  I bought another that I'm planing on using in my '67 GTX.
mopar0166
Looks great, ill be using electric fans, so im not to worried about the fan shroud.  Look ed like a great product and it lloks to be confirmed to cool ok as well  thanks again
