seal leak
Started by meanmarine, April 04, 2009, 09:06:08 PM
meanmarine
I notice a little oil leaking out of my rear wheel seal after sitting this winter. Do you think this will stop afterI start driving it again this spring? thanks
mikepmcs
Are you talking about the wheel cylinder as in the brake wheel cylinder.  If so, I would replace it immediately.
squeakfinder
 Whatever it is, I don't think it's going to just stop leaking. If you think it's gear oil check the vent for the axle to make sure it's not plugged. It's a little cap that you should be able to spin back and fourth between your finger's. Doing so will knock dirt out of it. If there is dirt that fall's out, it's possible that pressure built up and caused oil to blow out a seal.
