Transmission Fluid
Started by SF-CHSE, March 21, 2009, 07:58:41 PM
SF-CHSE
Where do you add transmission fluid on a '68 Charger?
Located the transmission dip stick near the firewall on the passenger side.
Pour the fluid down the thin dip stick tube?
SF
flyinlow
yes.
Check warmed up idling in neutral with brake set.  Do not overfill .
FLG
squeakfinder
 Use a funnel, they sell one at wallmart for less than a buck. But yes, thats were you ad fluid....
SF-CHSE
Thanks guys.
Gasket on my transmission is leaking allot of fluid.
Need to have it repaired.
But in the meantime will add fluid via the dip stick tube.
SF
FLG
You could go to your local parts store and pick up a gasket. There inexpensive and it only takes a couple of bolts to remove the cover and replace the gasket. Could also do a filter and oil change while your at it.
SF-CHSE
Good thought.
I need to purchase some jack stands.
Looks like my basket at the part store will be full.
SF
Might also want to check and just ensure the pan bolts are properly tightened, sometimes they can loosen up and let fluid leak.
Although FLG's advice is better with it being such cheap and good insurance.
FLG
Yep. And dont go cheap on the stands. I use a old set of the big 5 ton stands (overkill) but i know there not gonna go anywhere. They have a VERY large footprint. As a extra precaution if its not in the way ill even leave the jack under the car just barely resting on the frame.
Also agree with ghoste.
SF-CHSE
I will admit getting under the car does scare me.
Had a bad experience 15 years ago with a '54 Hudson.
I'll look into the 5 ton stands.
SF
Sublime/Sixpack
Yes, safety first!     :yesnod:
wayfast1500
I had a bad experience working on a 1988 bronco 2.  I was changing the leaf spring, it was a long project so I left the truck on 2 jackstands, had the jack barely touching the frame, and a tire under the frame.  I thought I was safe since I was doing everything right but having the truck set up like that for a month weakened the frame, the frame buckled, jack slipped under the truck into the floor pan, jack stands fell over because the truck rolled a little.  This happened while I had my legs under the rear drum.  The truck fell, luckily the drum landed inbetween my knees and I had to jack the truck up so I could get out.
