Seat Dimensions
Started by gasoline_24, March 20, 2009, 09:51:23 PM
gasoline_24
Does anybody have the dimensions of the upper and lower rear seat frame?  I took mine with my legendary covers to the upholstery guy and he says the covers are so tight that the frame is showing through.  I called legendary and they said there is no problem with the cover as that is the same one they have always made and there have been no other complaint.  I may have the wrong seat in there, but if fit alright when I removed it.  If somebody has the correct dimensions as far as width and height it would be appreciated.
gasoline_24
Anybody have these dimensions?
runningman
I have a seat frame in my attic, I will dig it out when I get home from work and post some info...
gasoline_24
Thanks.  I need the upper portion dimensions the most.
runningman
I will take some pics also...
runningman
Okay, here are the dimensions I got.  The seat bottom is 20" across the front, 18 1/4" across the back and 21 1/2" front to back, the top frame is 15 5/8" across the top, 20 1/2 across the bottom and 21" from the top of the frame to the bottom.  The top measurements don't include the side pieces that are used to mount the seat to the bottom frame.  Confusing?  I didn't get any pics yet since I can't find my camera, if you need some let me know.....
gasoline_24
how about the measurement that goes from the back (part against trunk divider to the front edge of the seat?
runningman
I guess I was assuming you were needing front seat dimensions for some reason.  You are needing back seat frame dimensions?  I have my back seat recovered in my basement but may still be able to get the dim's off of it.
gasoline_24
that is correct the back seat.  I was thinking those dimensions sounded small.
runningman
Quote from: gasoline_24 on March 25, 2009, 10:30:27 AM
:smilielol:  Yeah sorry about that
The back seat bottom dimension is 21" front to back and 59 3/4" wide, if you need the top still let me know and I will dig that out too.
Matt
gasoline_24
If you get a chance I would appreciate the top measurement.   :2thumbs:  Thanks for the help.
runningman
No problem, I will do that today when I get home.  Is that lower dimension close to what you have?  My covers are a snug fit too but they look good.  I also got them from Legendary
gasoline_24
I am not sure as they are not at my house, but I will go over and measure them and let you know.
runningman
Okay the upper is 55x22....
BROCK
I recall the lower frame showing through at the front corners on most 2nd gens.
I do not recall the upper frame showing through though.  I could be wrong about
that.  Perhaps there is a piece of padding that should be wrapped over the upper
frame?  I'm curious to see pics!
Let your music be in transit to the world
