Oil filters
Started by GN, February 23, 2009, 06:06:55 PM
Oh I think absolutely.  Everything we've been discussing since then has just been carcheology.
flyinlow
The 51773 filter. Is that off of a cummins diesel? Any drawbacks to using it , if it fits?
I use the K&N long filter on my 440 and i have 2 inches of room in front of it.
ok i have seen them even SHORTER than those
Quote from: Nacho-RT74 on February 26, 2009, 01:21:25 AM
yep thats what Napa sent me  only about 5 inches long ,,don't even extend past the K frame , a pain trying to get the oil filter wrench on it  :flame: will go back to the long ones when i do the next oil change  :yesnod:
runningman
You guys see the Wix filter discount that is posted over on Moparts?  Not sure how good a deal it is but there are a bunch of guys buying direct...
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Number=4344329&an=0&page=0#Post4344329
RD
Quote from: flyinlow on February 25, 2009, 11:18:13 PM
no drawbacks at all, great filtration and gets an extra 1 1/4 qts of oil into the system.
the filter is a match i did in the catalog.  the diesel filter is a 51607 and is a tad shorter than the 51773.  i believe the 51773 is off of a ford application, but not sure.  I based the match from the WIX catalog and found the same pitch/thread/size screw-on female end and the diameter and width of the seal.
I have ran this filter in my 72 charger w/400 and have had no issues at all.  oil pressure stays around 78-80 psi (cold) w/hi-volume oil pump on stock pan and 10w-40 oil, and 74-76 psi (hot).
doctorpimp
My 73 318 didn't have the adapter...
Maybe just the A & E bodies???
