Water Pump
Started by GN, February 16, 2009, 05:59:16 PM
GN
Is there a weep hole on top of the water pump under the A/C compresser? (74 Charger 318 engine). What would cause it to weep? Would a new radiator cause to much pressure? I can't see if it is the heater hose that may be leaking because of the a/c unit. Must the pump be replaced?
Some pumps have a weep hole in the bottom but I've never seen one in the top. If the leak is on the top I would suspect a thermostat housing gasket or hose.
