TQ carb
Started by dkn1997, February 06, 2009, 12:56:26 AM
dkn1997
Can I run a TQ on my performer RPM manifold without an adapter? it has two sets of bolt holes in it, but is the spreadbore more than just the bolt holes?  I ask cause I'm interested in a tq, but I have zero hood clearance with this manifold as it is and I don't want to add an adapt in there too....I may have to put spacers under the K frame to lower the engine..
RECHRGED
as far I know, you will need an adapter.
Rob R
Quote from: dkn1997 on February 06, 2009, 12:56:26 AM
First you'll need an adapter with an RPM intake...I think the performer will let you run a TQ.
Now as far as putting a spacer in between the cross member and frame to lower the engine  :badidea: You have to modify the motor mounts themselves...blocks will cause a catastrophic suspension failure. :Twocents:
Rolling_Thunder
Quote from: Rob R on February 06, 2009, 02:15:34 PM
not necessarily - alot of cars have lowered the K-member - look at hemi Darts...    with pulling the front wheels and hard landings nothing ever happened - but it is a bit unnerving i agree
Rob R
Rolling...
Those are race cars not cars clucking around town putting a 1000 miles a summer on or more.
Every car that I've personally seen with blocks in the front suspension have suffered from torsion bar failure and rear torsion bar cross member problems plus suspension part issues...
But I have to admit I've only seen 4 cars in over 30 years with blocks...maybe our streets are just not as good as most...But it wouldn't be my first choice for correcting under hood clearance issues. :icon_smile_wink:
Rolling_Thunder
Quote from: Rob R on February 06, 2009, 04:21:37 PM
Rolling...
Point taken
Why not save yourself a LOT of headaches and just run a different carb?
dkn1997
I've always wanted to run a TQ. I have heard such good things about them and they are  cheap...even from demonsizzler completely rebuilt.
I am currently running a 750 mighty demon and it's a good carb, but I am never satisfied leaving things the way they are.
RECHRGED
Rolling...
Well, i know a few who've run the lowering blocks with zero issues. I've never even seen a snapped torsion bar allthough i've heard of it happening. As far as the accelerated steering component wear i'm skeptical. Bump steer actually improves with the blocks installed. I have absolutely no concerns running them in my car.  :Twocents:
flyinlow
A simpler way I was looking at might be to have a good welder build up the area around the secondarys and then open up the inlet as required. I was looking at that myself, but have not tried it yet. I bought the intake used so I would not be out that much.
Saw two Holley SD. intakes at swap meet last week under $100 each. TQ fits these and they are lower. Single plane though.
dkn1997
Quote from: flyinlow on February 06, 2009, 08:52:12 PM
that thought had crossed my mind too.  but this is a pretty stock build and I don't know how she'd react to a single plane intake.
RECHRGED
Rolling_Thunder
why not get a stock TQ intake and port the hell out of it ?
dkn1997
Quote from: Rolling_Thunder on February 07, 2009, 12:32:21 AM
I was hoping to just throw a carb on it!! lol hahahhaha..now i'm porting intakes!  maybe I'll end up compromising and get a weiand action plus or some other intake that's not quite as high as the RPM....or maybe I'll just find a way to make a TQ work with a performer rpm and the adaptor.
RECHRGED
Kevin, if you really want to use a thermoquad just buy a Holley Street Dominator intake manifold. The TQ will bolt right on and you will actually gain some hood clearance.  :yesnod:
It will loose a little torque down low but it will gain some top end power....small trade off.  ;)
