firing order
Started by darkside, November 04, 2005, 11:44:28 PM
darkside
Can someone post a firing order diagram for a 383-440? thanks
toqwik
darkside
anyone have a distributor diagram showing correct firing order ?
General_01
Number 1 should be marked on the cap. Then go counter-clockwise in the order toqwik gave you.
1971 Dodge Charger Super Bee
496 stroker
4-speed
andy74
 :iagree: counter clock wise,not like a small block
do go from the cap , it is generally wrong , pull #1 plug & bump the engine over until you feel compression with your finger over the hole then look to see which tower on the cap the rotor is pointed to
