Engine ID
Started by GN, January 18, 2009, 01:40:38 PM
GN
Where is the engine stamping on a 74 318 that gives the year made, plant, etc. located at?
Look on the drivers side front of the block just below the cylinder head.
GN
I did manage to read the numbers. GM318R 35190014. I belive it is a 71 engine. So, this could not be the original engine on a early production 74 year?
Not at the rate they were using 318's.  Hemi's were sometimes cast ahead and waited for a bit before being used but the 318 was a steady go.  And you are correct, it is a 71 engine by that number.
GN
I also found the numbers 7181 411 stamped in front. What do they stand for? How do the numbers match on the small blocks?
Alaskan_TA
GM318R 35190014;
G - series (model year) 1971
M - Mound Road engine assembly plant
318 - 318 CID
R - Regular fuel
3519 - Final engine assembly date from the 10,000 day calendar - March 17, 1971
0014 - 14th engine assembled at this plant on the day above.
For the partial VIN of the car it came out of, look on the passenger side of the engine for a raised pad. It is down low, about center (front to back), right above the oil pan rail.
