Wheres yer Coil?
Started by Moparbob, January 17, 2009, 08:07:51 PM
Moparbob
With a Holley Carb and double fuel lines it appears that the standard coil mounting would be tough, Where is everybody mounting their external coils on 440's with hi pro manifolds?
Bob Norris
www.moparbob.com
God Bless America.
Quote from: Moparbob on January 17, 2009, 08:07:51 PM
I prefer to mount them on the inner fender....away from vibration and heat.  :2thumbs:
Moparbob
Quote from: firefighter3931 on January 17, 2009, 08:26:16 PM
Hmm,, Whats about da fire wall?
Gonna use a basic coil:
http://store.summitracing.com/partdetail.asp?autofilter=1&part=ACC-140001&N=700+115&autoview=sku
Bob Norris
www.moparbob.com
God Bless America.
Quote from: Moparbob on January 17, 2009, 08:29:45 PM
The firewall is too far away from the distributor. Works ok with a smallblock because the distributor is at the back of the engine. I like to keep the coilwire 12-16in long.
yep the factory placement is not a very good place..  especialy for heat  , been thinking to mount mine on the inner fender for years (best place i think ) ..but it don't look stock :scratchchin:
bordin34
I had mine on the inner fender, now I have an e-coil on the inner fender next to the alternator
1967 Coronet Black 440 Auto
Mahwah,NJ
Moparbob
Any other pics or coils on the inner fender? I dont know what else goes on that side if the car,, some kind of vent jug or something?
Bob Norris
www.moparbob.com
God Bless America.
FLG
What your referring to is the charcoal canister for the gas tank vent. I had both the canister AND the coil on the inner fender (on the inside not the top) i then modified my gas cap so it now vents out of the cap and was able to plug the vent line and remove the canister.
Moparbob
Quote from: FLG on January 17, 2009, 09:11:39 PM
Thanks,
I dont have the charcoal canister and perhaps I can do the same. Its got a locking gas cap (not stock) and I bet it already vents. Any suggestions on that while were here?  :pity:
Bob Norris
www.moparbob.com
God Bless America.
FLG
Depends, the cap i had was also "vented" but there was quite a bit of pressure required to push the spring open to vent through the cap and i was getting a very big buildup of pressure in the tank with the charcoal canister line plugged so i took the cap apart and cut the spring a bit so it takes alot less pressure to vent the tank.
histoy
You can contact Greg at Fabulous Fabrications (303) 666-9882.   He sells a coil relocation bracket that attaches to the intake manifold.  It works great, if you want to use a standard type coil with the Holley dual feed lines.
SFRT
front PS inner fender under the fluid wash bottle
Always Drive Responsibly
Uploaded with ImageShack.us
69bronzeT5
I don't have a 440 but I have a 383. My coil was in our lawnmower. I took it back when the lawnmower broke and now it's sitting on my shelf. My bracket for it is still on my intake manifold. Don't worry, I'm not gonna use the old coil. :icon_smile_big:
Runner
i always put it like this.... sometimes i mount them slightly different but all of them are in basically the same place
Quote from: histoy on January 17, 2009, 10:42:56 PM
I used his but had to modify it a bit to get it to fit with my drop base air cleaner & my CH4B
.....and for the next question here's where I mounted my ECU  ;)
chargerbr549
Another option that might work is to use the coil bracket for the 6 pack motors, they mount the coil to the middle two intake manifold bolts, a friend of mine has this setup on a holley street dominator and speed demon carb on his 440 and it looks pretty good.
Kevin
62 Max
Or make your own
62 Max
Another
