stupid question
Started by greenrt_se, November 03, 2005, 10:21:43 AM
greenrt_se
Can some problem in electrical circuit make motor idle quality bad??  my charger motor shaking in idle speed,vaacum is steady (14")
demon carb(new) and A/F ratio is ok, in idle speed,motor is whit: 0,030 2355f piston 0-deck
        223/228 0,050 Hydraulic cam
        1,6:1 roller rockers  pre load 3/4 turn
        84cc E-head (out of box)
        RPM intake
        hp exhaust manifold
        new timing gear,damper,piston rings
ignition is MSD ready to run distributor,blaster coil,ngk plugs
I have ground wires hook to the head?? next I put them to the motor ears
It could but I'd cover the basics first.  Are your plug wires new?  Are they all on?  You need to find out which cylinder is not firing.
I have had constant problems with NGK plugs foulfing & misfiring , Use Champ or Autolite
