68 CHarger Updated
Started by G-man, December 23, 2008, 12:04:08 AM
G-man
Hi
I just baught myself a 750cfm Double Pumper Holley HP Street carburetor for my stock 383ci 68 Charger. I also got a Wieand Action Plus Dual plane intake manifold. Replaced the old coil with a Pro comp coil (40-50 000 volt) and NGK IRIDIUM spark plugs to replace the crappy Champions.
This car now hits 80mph in 2nd gear. I couldnt believe it can go that hard with a stock 383. Still running the rubbish original headers. WHen i stick 3" collectors on with new exhausts... Wonder how good it will go then.
You also can not beat a DP carby. Totaly responsive, does what you want it to, power is there instantaneously and its more economical than a Vacuum secondary (if you control your foot to drive off primaries only/all the time)
Dont even know why they make VS carbies.
Sublime/Sixpack
Curious;  what gears (ratio) do you have in the rearend?
G-man
Dont know. When I replace my clutch with a heavy duty clutch (Next week) should be able to tell you the Ratio.
I believe its more than 3.23.
Might be either the 3.91 or the 3.53 (or whichever the one is inbetween)
Blade_1
Quote from: Sublime/Sixpack on December 23, 2008, 12:12:44 AM
Vacuum secondary or mechanical? I took my Carter off and put on a 780 duel feed, but it was vac secondaries uh huh.
And school bus gas don't go well into 12.5:1 squeeze, and you can't light up for at least 3 days cause school bus gas tastes bad yup.
80 in second? Sounds like a 3.23 in back! Or 3.08...
skip68
 :scratchchin:  Two words come to mind when I hear 80mph in 2nd.  REV LIMITER.  :yesnod:  If you got one great. If not, get one.   :Twocents:  Do you have an electric choke?   I can't wait til I get my new carb but I guess I'll have to.  Any pics. ?   :drool5:  :2thumbs:
G-man
The 750 cfm HP street Holley has NO choke (mechanical secondaries - Double pumper)
No choke is awesome also.
Revs... Might off been 7000 I know it was screaming its head off and I dont have a RPM gauge...
Will get pics off all the new goodies on the car... give me a bit of time.
charger Downunder
Good to here its coming along well.
[/quote]
Joshua
Quote from: G-man on December 23, 2008, 04:21:54 AM
Hmmmm.....you think @ 7000rpm with a "stock" 383 eh???? The valves will float way before then... :Twocents:
And if you don't know why they make VS carbs????? Really???:slap:
RPM gauge???
You talk funny..... :nana:
Good luck with the DP on your stock engine........they are a good carb. :2thumbs:
