d6
Started by chargeral, October 08, 2008, 07:51:48 PM
chargeral
Hi Guys. I just purchased a 69 hemi engine basket case.It has 1974 set of D6 heads. One was repaired at some point and was reasured it was fine. I have no dought to believe otherwise.Head has been machined .045 (differance between both heads)  My question is ,   is it wise to stack an extra .045 gasket on the one side or should I look for another set of heads and is everything transferable to another set of aluminum heads.  The more info the better.   Thanks  Al
Rolling_Thunder
just have the other machined the .045 and have the intake milled to match    :Twocents:
chargeral
Thanks    Will do.
