Ignition Switch
Started by Jesco, September 15, 2008, 12:53:58 AM
Jesco
Hi,
Without even have had a look - is it hard to reach the connectors/spades on the ignition swith? Or is it easier to take the switch out of the dash and add a cable to one of the connectors.
Wich cable (color) to the ignition switch have switched 12 V (stock harness 69 charger)? Wich is best to install a guage to?
Thanks!
1964 Dodge 330 Super Stock Clon
1969 Dodge Charger R/T
FLG
Do you just need a "key on" feed for your gauges?
Jesco
The dark blue 16 gauge wire from the switch is ignition run, if you want the guage to also work in the accessory position you need to tap the black 12 gauge wire from the switch.
Jesco
