73 shocks
Started by flyinlow, August 09, 2008, 11:02:50 PM
flyinlow
I can not find a high capacity front shock for a 73 charger. twin tube kyb is marginal.
Any other choices?
By "high(er) capacity" are you wanting a firmer ride ?
The Edelbrock IAS shocks are excellent but not cheap.
hutch
Quote from: flyinlow on August 09, 2008, 11:02:50 PM
Any other choices?
Your car is not a big block transplant is it?  Might be something you can fix with your t-bar setup as well.  I am dealing with the same issue with my 73.   Brock reminded me of the front t-bar springs in our cars and moving to a 440 in my car might be too much for it if it has smaller factory bars for a 318 or something.
:Twocents:
In the words of Colonel Sanders,,,   "I'm too drunk,,, to taste this chicken"
flyinlow
I looked at edelbrocks . They dont have a listing for 73 and up on the front.  The rear ones are avialable. I have gas charged kyb monoshocks in the back ,they work well with new Mopar HD springs. I had to go with the basic twin tube in the front.
Car was a 318 car,now a 446. Torsion bars are .920 diameter. which is  the same as big block bars from what I can find. With aluminum heads/intake /headers/ rad./ VFN fiberglass bulge hood /ac removed and the battery trunk mounted , it  weighs about the same in the front as it did with the stock 318.
Mancini sells .960 bars , will probably install this winter.
Front shock body is only about 7 inches long.
