horn problems
Started by 69 rt, August 06, 2008, 08:47:12 AM
69 rt
Is there a way to check a horn to see if it is any good? All i get is a clicking sound when I press the horn button. Any help would be appreciated
A jumper from your battery to the terminal on the horn.
Rolling_Thunder
yep - double check the horn is grounded well and put 12V to the terminal...    there is an adjustment screw on the horn as well...    :shruggy:
histoy
Sometimes dirt gets inside the horn and keeps it from working.   I've had luck getting it out by removing the horn and tapping it on a block of wood, or by tapping the horn with a small hammer.
