727 specs
Started by koshe, July 28, 2008, 10:54:07 AM
koshe
I am going to service my transmission. What are the torque specs for the bands?
RD
72" lbs for front and back
rear band: tighten then turn adjustment screw two turns counterclockwise then tighten adjusting nut to 25 ft/lbs if my memory is correct
front band: tighten then turn adjustment screw in between 2 and 2 1/2 turns based on the type of motor  ( 2 1/4 turns is a safe bet), and then tighten adjustment screw to 25 ft/lbs (again if my memory is correct)
koshe
Is there a spec for how tight the screws are turned in inch pounds? I am serviceing my transmission and would like to make sure the bnds are adjusted OK as long I have the pan off.
RD
" = inch, sorry about that
72 in/lbs for the front and rear adjustment screws, then you have to back off the screws as shown above.  let me know if i can be of any further assistance.
