Carbs and weather.
Started by CFMopar, October 15, 2005, 01:07:34 PM
CFMopar
Since its getting cooler out I want to confirm.
When the air is cooler do u you richer or leaner? I figured richer cause the air is more dense so you need more fuel....
I know when its humid you can run leaner. What bout a dry heat?
Anyone want to confirm?
1971 Charger SE 440 automatic
2014 Ram EcoDiesel Laramie
my experience shows thew opposite , cooler weather seems to condense the fuel more than the air so generally I find the idle mix needs to be leaner
67_Dodge_Charger
Cooler air means more hp.   :icon_smile_cool:
Robert
CP, that is an interesting observation based on what one would think an engine wants.  What I mean is, a cold engine needs to be choked to get it running, mileage improves in the summer and so forth.
How much leaner do you typically find you have to go?
1/4 turn of the mixture screws or less
